HP vs. TQ
Old Nov 27, 2007 | 01:55 PM
  #31
ohiomotoxer's Avatar
ohiomotoxer
Default RE: HP vs. TQ
Get an air shifter, high pressure Co2 bottle, and an MPS autoshift, set the shift point to 6K,wack the throttle WFOand hold on !!!
That's what I do......cept for the shift point
Old Nov 27, 2007 | 03:08 PM
  #32
Clammy's Avatar
Clammy
ORIGINAL: sharkey
Here is my dyno. Note that I have 100ft lbs from 2200rpm (Thankyou HQ). When I ride, I normally keep it between 2000 - 4500rpm. After a while you can "feel" it...but when I want some metric cruiser for dessert, it's shifted as it hits6000. From a first gear WOT run, the front wheel will "float" about 6-8 inches thru second then pop up again in third and settle down by the time I grab fourth...all quite quickly. (It don't spend any time in first...) See how that relates to the power curve; or rather, plateau.....
[IMG]local://upfiles/32069/A13065F31C334C19A17B125AF144A17D.jpg[/IMG]
[IMG]local://upfiles/32069/635043C600294724A92737A8466EE504.jpg[/IMG]
Hey sharkey,
That's a good looking dyno sheet.
What are the specifics of your build and what exhaust are you running, if you don't mind my asking?
I got my heads done by HQ and installed a set of HQ-0039G gear drive cams and an HQ-6104 ignition last winter, which with stock 88" @ 9:1 compression and a crappy tune on my carb gave me 83 hp/89 ft-lbs. This winter I will complete the build by going to 95" @ 10:1 compression and removing the Dynojet kit form my carb and installing the HQ-2525 carb kit.
Thanks.
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
Old Nov 27, 2007 | 06:42 PM
  #33
faber's Avatar
faber
This is an interesting thread! Thanks for getting the ball rolling, Herr Monk, and thanks for all the good replies, everyone. Will look at those links soon.
I'm going to take a shot at being wrong here and WELCOME being corrected.....I'm here to learn
TQ is really a nearly useless quantity unless it is measured at the rear wheel, true? It is a measure of the output of the whole drive train (engine, primary, and tranny). We lose TQ as we approach the upper end of the gear, because with our low-revving air-cooled V-twins, we run out of engine performance (RPMs) to apply power--ergo the diminishing returns at the upper end of any gear. Thus, we gear them to get all the turning force at lower RPMs than a sportbike.
HP is a measure of the engine's capacity to produce power. Period. That's why sportbikes are designed to rev well north of 10K and can do impressive roll-ons at 90mph and accelerate like they are just taking off from a red light. An engine that can produce it's HP across a broader performance (RPM) range will produce more TQ in any gear.
The two quantities have to be considered together: with an engine's given HP, we can manipulate the TQ (output) simply by changing something in the gearing. When we change the gearing to get more off-the-line zip, we sacrifice upper-limit performance. Obvious. The engine/drivetrain can only turn so fast. But when we change something in the engine (cams, exhaust, intake, etc.) we can make it easier for the engine to put out more power at different points in the powerband before max HP is reached., generating more TQ (output) at lower HP/RPMs. Thus, Stage I, Stage II, etc.
Harleys are often able to generate more TQ at a given (low) RPM than a sportbike, but a sportbike can push a lot more HP into any gear. So wen we talk about enjoying the feeling of TQ when we zip around from red light to red light, we are really talking about enjoying the TQ in *that gear* in that (low) RPM range. But when we are doing 50mph in 1st and try to accelerate, we are no longer praising the TQ.
Or at least that's how I understand it. But I'm scratching my head as I type this. I tend to overthink things, and I'm not an engineer. But, I really don't think about this stuff until the bikes are in winter storage and I forget about it in the spring
What I'm really curious about is the limitation of the air-cooled V-twin. Why is it limited to a short powerband? Is it that without the ability to regulate its own temp, the engine will heat up and expand at a certain (high) RPM? And that's why the rev limiters? Total guess--I have no idea.
Old Nov 27, 2007 | 09:59 PM
  #34
Clammy's Avatar
Clammy
ORIGINAL: faber
The main limiting factor in the rpms HD engines can take is the 45 degree angle and long stroke. If you think about it, there's a lot of mass moving a long distance up and down, and that creates a lot of stress, so the point of breaking is lower engine rpm. High revving engines have a much shorter stroke, and thus have less distance for that mass to travel. As a result, it can spin faster before the stresses break it. Another thing is HD engines have a lot of displacement between only 2 cylinders (hence the bore and stroke being relatively large and long). When you get into 4, 6 cylinder engines, the pistons can be made much smaller and consequently lighter, so now you have less mass as well as less distance for the piston to travel, and all of a sudden you can rev that motor up to 16 grand and be just fine.
Now, a huge benefit of a longer stroke engine is that you get a lot of low rpm torque because each power stroke, has a heavier piston traveling a longer distance which creates a "stronger" pulse with each firing of the spark plug.
Hope I got all that right, heheheh...
Cheers!
Old Nov 27, 2007 | 10:13 PM
  #35
Herr Monk's Avatar
Herr Monk
So does that mean that a 103" is a lower reving engine than a 96"?
Seems like by that logic a stroker will have more low-end, and less high-end than an engine with the same bore, and less stroke. Is this true? Do you folks with 103"s and 107"s have to set the rev. limiter lower?
Old Nov 27, 2007 | 11:28 PM
  #36
Hap_Hazard's Avatar
Hap_Hazard
ORIGINAL: Herr Monk
(cut some)
How does tq versus hp at a given rpm translate into acceleration/seat of your pants feeling?
Thanks
Horsepower is how fast you hit a wall, Torque is how far you take the wall with you
Old Nov 28, 2007 | 12:04 AM
  #37
faber's Avatar
faber
I get the bore & stroke issue. Thanks for spelling it out, Clammy. Cheers to ya.
Before I got my Harley this year, I messed around with 70s-vintage 650s/750s (Triumphs and Yamahas, mostly--still have a few). But I know what made the Hondas stand out back then was going to the 4 cyl 750 with smaller cylinders/pistons--essentially the first modern sportbike. But they just don't have the low-end pull of my old Bonnie or XS650s. That's my simple-minded way of understanding the difference between HP & TQ.
But.....the L-twin in the Ducati 1098 puts out 180hp stock! With 99 ft-lbs TQ (at a slightly lower RPM then peak HP, I'm guessing.) Calling that bike stock is like calling a Lamborghini stock, I know. The bore is bigger than HD but the stroke is shorter, as I recall (someone can look it up). So...more piston mass through a shorter range of motion and thus able to rev higher, I guess? And maybe the 90° angle gives engineers a little more breathing room to design for higher output (RPMs), as opposed to our iconic 45° twin. But the Ducati also is liquid-cooled and street-legal AND track ready--no Stage I/II, etc.
So, it's not the air-cooled issue that has us HD owners tuning for TQ, but the long-stroke V-twin. I guess I've been misled by those who hope that HD releases a liquid-cooled V-twin for the whole line. That would be good for other reasons, I guess, but not necessarily affect HP/TQ, right?
Winter storage.....
Old Nov 28, 2007 | 01:14 AM
  #38
sharkey's Avatar
sharkey
Clammy; mine is a 103 with hq heads, ign, 033G cams, 51CV and the dyno was done with 2" Cycle Shacks. I've since put on V&H stepped drags with quiet baffles (Pictured...)
One of my brothers has a very stout 95" by HQ with the 39 cams; believe he's at 100/100 with lots of torque down low...bikes built for his 300lb carcass...
Gone for a week now; see ya'll later.....
[IMG]local://upfiles/32069/E965C38ED6704C58B58FCB58A70F78AE.jpg[/IMG]
Old Nov 28, 2007 | 01:37 AM
  #39
ebeattie's Avatar
ebeattie
Only time you'd honestly EVER need to worry about when and where your engine is making power is when your racing... be it for money, slips, braket racing ect.
as others have stated, use yer butt and yer head and the situation involved to figure when to shift.
Old Nov 28, 2007 | 05:51 AM
  #40
Clammy's Avatar
Clammy
ORIGINAL: sharkey
Thanks for the info! I'm looking forward to next spring to run my 95"er, and just to be free of winter, hehehe...
Cheers!
