Water inside frame
Old Dec 17, 2007 | 04:07 PM
GPHDXLC's Avatar
GPHDXLC
Default Water inside frame
On my 06 1200-C I got last month, I went to put in new fluids, Amsoil in the motor, and Mobil 75-90 in primary. I got it hot and after I changed the fluids, I started it back up [in storage cant drive it] I put it in gear and took off across my garage as fast as I could safely, to work in the gear lub.
I look back and see a long strip of what looks like oil on the floor. I know I had the drain plugs back in tight. I go into a 'PANIC' turn off the motor and touch the fluid on the floor 'it's water' I could not believe it. I dont mean just a drop or two, the strip of water was about 10 ft long. I had my wife come out and watch me run my bike back and forth and she cuuld see the spot it came out.
On the left side bottom of the frame just as it starts to curve back upat the rear, there is a factory hole about 3/16" in the frame, thats where it pukes out under forward motion.
So, I drill a 1/8" hole in the very bottom of the frame and out comes more water, all together I would say about 3-4 oz came out. Now just to be safe I drill a hole on the right side frame and out comes water, but not as much maybe 1/2 oz. I cant see a factory hole on the right side,to much partsinthe way. Im going to tap in screwsand addSilicone in the drain holes I made.
So how did the water get inside the frame?
I did wash it real good about 2 weeks befor, the guy I got it from said he did get caught in heavy rain in August. I can tell it never set in water, I took off some parts on the bottom and reinstalled, did the same with some bolts there was no sign of water or rust anyplace.Very clean and dry.
Do all of you think this is a problem unique to my bike? Sportsters? or all Harleys. Is this a common thing? No one in my Harley group has seen this befor. Some of them are about ready to drill drain holes in ther frames.
So has any one of you heard of this?...
Gary.
Old Dec 17, 2007 | 04:09 PM
schumacher's Avatar
schumacher
Default RE: Water inside frame
flood bike?
That's really odd.
Old Dec 17, 2007 | 04:17 PM
Dorkman's Avatar
Dorkman
Very likely a weep hole to let out condensation. I've seen this on other bike parts.
Old Dec 17, 2007 | 04:19 PM
GPHDXLC's Avatar
GPHDXLC
No it's not a flood bike. I know the guy I got it from. But as I said I did take off some parts on the bottom just to make sure he didn't let it set in a water hole or something like that. He lives on a farm and he stored it in a shed with a dirt floor, but it never floods or gets wet inside...
Old Dec 17, 2007 | 04:26 PM
BillyO's Avatar
BillyO
Definitely NOT your radiator.
Old Dec 17, 2007 | 08:13 PM
cardoctor's Avatar
cardoctor
you must have purchase the rare one -off water cooled sportster
JR
Old Dec 17, 2007 | 08:28 PM
Cynic's Avatar
Cynic
ORIGINAL: GPHDXLC
Gary.
They all get water in them. If your **** about it search the aircraft catalogs for creeping oil, that's what they use in the airframes...
Old Dec 17, 2007 | 08:56 PM
1flhtk4me's Avatar
1flhtk4me
ORIGINAL: GPHDXLC
You must have a long Garage!
I would also stop drilling holes in the frame!
Old Dec 17, 2007 | 09:11 PM
xxxflhrci's Avatar
xxxflhrci
Water getting in the frame is not uncommon. It just shouldn't be trapped there.
Many Touring bike owners are gonna get a surprise when the rear of their frame rusts out in a few years. HD has known about the problem for over 10 years now. I spray oil/WD-40/Seafoam, or whatever, in mine a few times a year to combat it.
Old Dec 17, 2007 | 09:18 PM
46knuck's Avatar
46knuck
I think I would leave the holes you drilled if all on the bottom side, since you may wash it real good again some day.
