Thundermax with autotune tuning problem
Old Dec 19, 2007 | 08:30 PM
otaramc's Avatar
otaramc
Default Thundermax with autotune tuning problem
2007 fxdwg
D&D Fat Cat
Big Sucker
T-Max with AT
Bike starts for 3-4 secs then dies... any ideas????????
Old Dec 19, 2007 | 09:46 PM
BOARGAURD's Avatar
BOARGAURD
Default RE: Thundermax with autotune tuning problem
simple questions first. Did you inialize the unit properly? Did it just start doing this? What was the last change you made to it?
Old Dec 19, 2007 | 11:39 PM
bdavis385's Avatar
bdavis385
Wrong map. My initial choice of maps for my bike was doing the same thing. Went to a map recommended by Zippers and it was fine.
Old Dec 20, 2007 | 12:00 AM
otaramc's Avatar
otaramc
installed as per instructions.
installed fatcat and bigsucker then initalised the unit.
installed base map item id - 382 (being the closest to my set up)
And it does the 4 sec routine then dies again.
Gonna try delete and re install
Old Dec 20, 2007 | 12:08 AM
otaramc's Avatar
otaramc
now it starts and dies after 2 seconds :-(
Old Dec 20, 2007 | 05:40 AM
claydbal's Avatar
claydbal
filter the maps till you match the best for a 103. the stroke is more important and lots of folk load a 95 or 96 overbore map. use 103 map.
Old Dec 20, 2007 | 07:26 AM
SpringerDude's Avatar
SpringerDude
If it still doesn't work, call tech support at Zippers. They helped me during my installation and were cool about it.
Old Dec 21, 2007 | 01:17 AM
otaramc's Avatar
otaramc
feels like running on one cyclinder.
down to one sec then dies.
ive checked install of tmax unit - good
even fitted new exhaust gasket to ensure no leak.
ran ok on the 382 map, was told to install 391. ran worse. went back to 382 and cant seem to get it.
Yes I initialised everyime I changed maps but stil runs like sh*t
after initialisng Heard a few clunks while trying to start. had to recharge battery 2x, and tommorow will be day 3 :-(
If any one knows this unit drop me a line (and yeah Ive called the techline but long story short they ran off, its true)
Old Dec 21, 2007 | 07:12 AM
claydbal's Avatar
claydbal
ORIGINAL: otaramc
you have symptoms of corrupt map.
try this,
clear IAC learning
clear fuel offsets
pull ecm fuse
install ecm fuse 30 minutes later
load map that worked
initialize
let idle to 289 degres
switch off
ride
Old Dec 21, 2007 | 02:35 PM
otaramc's Avatar
otaramc
shes going now, and much much better. thanks 4 all the tips guys :-)
