winterizing, yes or no?
Old Jan 10, 2008 | 02:34 PM
Dancemax's Avatar
Dancemax
Default winterizing, yes or no?
If I decide not to put it away for 5 months of Michigan winter, what do you think is the minimuum riding I must do to keep it in shape. I get my HD Softail out of garage once a month and ride for about 25 minutes with about ten minutes on the highway at good throttle and speed and when I park it back I make surethe wheels touch different ground spots. Is this enough or what do you think, all comments welcome. i do add a little gas stabilizer to 1/2 tank of gas. Then I cover it good with a thick blanket and a cover. Battery connects to a tender.
Old Jan 10, 2008 | 02:42 PM
Hounds2's Avatar
Hounds2
Default RE: winterizing, yes or no?
don't ya love michigan? i change all my oils when i put it up in the fall...i usually try to ride at least a couple times throughout the winter. about april 1 i give her hell for another season. i think the bike is fine. i too put stable in the gas. i also wash the bike good if there might be salt on the road (just rinse it down actually). i think people make to much of winterizing. i ride until late november usually. even if it sat till april i dont see how there could be any problems. condensation would be your only enemy and that shouldnt be a probem if you run it till its good and hot...as a matter of fact i road mine for a little while today...supposed to have a winter storm tonite...good luck
scott
Old Jan 10, 2008 | 02:57 PM
MyFirstHD's Avatar
MyFirstHD
Where in Michigan? Must be up north if you get 5 months of winter.
Change the engine late in the year so that dirty oil don't settle, separate or corrode anything.
I put a little Stabil in on my last ride before the first big snow, usually end of November, some years in December.Use SeaFoam in the spring.
This is my first EFI bike (bought it this October) and this winter. Road it the dayafter Thanksgiving,day after Christmas, and thisweek. If and when I doride during the winter it's atleast 45 minutes and I try toget the engine good and hot. Then I try to put it in the garage as soon as I get home instead of leaving it outside tocool.
Downriver Detroit here, where are you guys from?
Old Jan 10, 2008 | 04:39 PM
Booey424's Avatar
Booey424
I live in Cleveland,Ohio.I have never "winterized" my bike.I actually rode it on Tuesday,January 8th.If I had winterized it I would be kicking myself for missing that ride.I have had my ride for 5 years and if it sits for too long I will go out and start it and let it run for 30-45 minutes in the garage. Also I have never had o charge the battery.It is still original from March 2003
Old Jan 10, 2008 | 07:01 PM
Gamma742's Avatar
Gamma742
WTF is wintering
Old Jan 10, 2008 | 07:13 PM
tmitchellof PG's Avatar
tmitchellof PG
ORIGINAL: Gamma742
WTF is wintering
You add antifreeze to the blinker fluid.
Tom
Old Jan 11, 2008 | 11:40 AM
1200rman's Avatar
1200rman
6th Gear
Having spent many years with boats that were stored for winter months, the process of storage used was honed to make sure there were no issues that resulted from inactivity. We used a stablizer in the fuel (put in an almost full tank..run for 5-10 minutes, then top off the tank to full so there's no condensation). Trickle charge the battery as you're doing. Lubricate anything that might need it prior to storing. As far as running is concerned, all that's needed is to get the bike up to operating temperature. A highway speed ride for about 10 minutes will do that and charge the battery too as well as push lubrication throughout the engine.
Then cover the bike (once cool), put the charger backand you can leave it for 3-4 weeks (again, after topping off to keep it full). We've stored boats without running for 6 months at a time in harsh winters and as long as batteries were charged and stabil. was used, they started right up with no problems virtually every time.
Good luck.
Old Jan 11, 2008 | 12:47 PM
Hounds2's Avatar
Hounds2
hello, i'm in ithaca....right in the middle of the state....i'm not going to live forever so if i get a chance to ride i'll ride. i get a charge out of the people that are afraid to ride in the winter as they might get some salt on their bike..i bought the thing to ride. i hope to wear this one out along with a few more. some simple precautions as stated here will keep things in order. i do however find myself a bit sensitive to cold as i get older. i rode a bit yesterday but never got over about 45mph.....any faster and my skin told me to slow down. should have used a snowmobile suit but i dont have one.
scott
Old Jan 11, 2008 | 12:53 PM
Wildcat68's Avatar
Wildcat68
Winterizing= carrying a bigger flask
Old Jan 11, 2008 | 05:48 PM
Sarge 154's Avatar
Sarge 154
I don't "winterize" because you never know when you can get out. I am loving that I can still ride in January! Sta-bil in the gas and if you don't get to ride at least once each week, start the bike and let it run for 15-20 minutes.
