Can leather be darkened?
Old Jan 17, 2008 | 12:00 AM
MidLifeCrisis's Avatar
MidLifeCrisis
Default Can leather be darkened?
Here's my problem
I bought a set ofKuryakyn Black & Turquoise Braided Levers with Fringe on ebay,I thought the colors would go ok with my Teal Roadking. (what was I thinking?) The turquise is too light so does anyone know if there is any way I can darken the turquise to a darker green? I have allready installed them on bike, can't send them back and don't want to buy another pair. Any help will be greatly appreciated
Thanks
Old Jan 17, 2008 | 12:06 AM
Kolni's Avatar
Kolni
Default RE: Can leather be darkened?
Yes, but I don't know how.
Old Jan 17, 2008 | 12:07 AM
Rhubarb's Avatar
Rhubarb
Try saddle soap or another oil based leather conditioner.
It will darken the leather similar to the color it will get when wet.
Old Jan 17, 2008 | 12:11 AM
xxxflhrci's Avatar
xxxflhrci
Yep, smear 'em with neats foot oil. Ain't got any? I'd just use motor oil. It sure has stained my tan boots a nice dark brown.
Old Jan 17, 2008 | 12:34 AM
sweet07's Avatar
sweet07
Ya might axe your local shoe repairshop
Old Jan 17, 2008 | 12:37 AM
anubisss's Avatar
anubisss
You could also try nulife leather spray from a shoe store...
Old Jan 17, 2008 | 12:48 AM
MidLifeCrisis
I will check into those possibilities and see what I come up with. I tried auto part stores and tailor shop but that didn't work out.
Thanks
Old Jan 17, 2008 | 04:35 AM
whaap's Avatar
whaap
Don't spray on any product that's applied like paint. It will only come off eventually. See your shoe repair man and find out where you can buy dye and that will take care of it.
Old Jan 17, 2008 | 05:17 AM
99octane's Avatar
99octane
Leather my be tricky.
You may use leather dye, that will darken it, but you must take into account that, for your leather to last, you'll have to maintain it, and conditioners slightly darken the hue of the leather.
So, first and foremost, try some leather conditioner and see how it turns out: maybe that with the conditioner the color will be ok.
If it's still too light, dye it with the appropriate product, but keep in mind two things: when dying, the color will appear DARKER than when the dye dries. When given conditioner, the leather will darken. Conditioned leather color will be somewhat between wet dye and dried dye.
Use LIGHT dying and see how it turns out. You may always apply more dye if it's still too light, but you can't easily remove dye once it's on.
A bottle of acetone comes in handy for removing conditioner or color, but be VERY careful: you can't treat just a patch, you must treat the whole manufact and you must remove conditioner uniformly, and all of it, or you'll end up with a blotchy finish.
Once blotchy, forever blotchy.
This is true even when applying dye: try to be as uniform and smooth as possible.
The best way is applying several light dyes, until you get the color you want, keeping a little lighter to take conditioner into account and then applying conditioner.
Light dyes applied with a paper towel dab are less likely to get blotchy.
Whatever the color tone, a blotchy finish on your leather is by far the crappiest thing you can get. [:'(]
Old Jan 17, 2008 | 06:04 AM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
I did a similar thing some years ago. I boughta Corbin seatwith red piping thinking it would look good on my red Heritage but then I didn't like it.
First, please think twice about using any conditioners right now. They mightrepel any dye. Some actually have silicone in them. Others may have oils.
I liked the seat so I decided to just dye it black. I cleaned it well with acetone (any paint store) which I'm sure wasn't the best for the leather but I was desperate.
Next I dyed the whole thing black with Kiwi shoe dye. That's not liquid shoe polish, but actual liquid dye. Next I polished it well with Kiwi neutral shoe wax and brushed it with a shoe brush.
It turned out really nice and I had no problems with fading or peeling or anything else.
Since then I've "renewed" older saddlebags etc. with the same method. It's done well for me.
I know this doesn't answer your question about getting the teal darker, but if all else fails...
PS I just remembered, leather hobbyist stores and suppliers carry all kinds of colors of leather dye. People actually "paint" designs on leather. You might try that instead. You might have to mix two colors to get what you want.
