TOO QUIET PIPES
Old Feb 5, 2008 | 03:18 AM
Sam's Avatar
Sam
Default RE: TOO QUIET PIPES
On the later bikes, carb or fuel injected made no difference when it came to sound. The "Harley" sound has been gone for years, blame the EPA. If you want quality and sound, then go with Vance & Hines, Bub Rineharts or Bub 7's.
Old Feb 5, 2008 | 04:21 AM
domenicp7's Avatar
domenicp7
Just get a set of quality pipes the V&H with quiet baffles run a low rumble and are not over the top loud but you can hear me coming. Reinharts are great also. I would not recommend running nobaffle by the way.
Old Feb 5, 2008 | 06:30 AM
biz44's Avatar
biz44
By just removing the baffle, it will only make it sound cheap....and to top that off it will totally destroy your bottom end torque. There has to be some restriction in the pipe to create back pressure, or you will loose some HP/Tq. When you say stage-1 are you including a exhaust system in that, or are you just running the stock exhaust with fish tail tips on them?
As far as the old Harley sound.....well they dont sound like that any more, but its not because of the F.I.....or the EPA. It has more to do with the engine itself....the "twin cam" engines will never sound like a pan head....never.
Old Feb 5, 2008 | 06:34 AM
capnron's Avatar
capnron
6th Gear
I'm a novice in these things, but I found this article that explained volumes.
http://www.mslmagazine.co.uk/features/mil-music.htm
Old Feb 5, 2008 | 08:53 AM
Ridewva's Avatar
Ridewva
ORIGINAL: capnron
Do the US spec'd HD's have this same exhaust set-up?
• Active intake and exhaust system
They did this by installing a butterfly valve in the lower of the two separate exhausts on each bike (the emissions catalyst is in the other), as well as a flap-valve in the air filter intake duct. These solenoid-operated devices are linked and controlled by the Delphi ECU, which in addition to its normal engine management function, has what must be an extremely complex additional programme mapped to operate these valves according to a variety of parameters - engine revs, road speed, throttle opening and gear selected. So fire up the engine from cold on the automatic choke and blip the throttle at rest, and you may be surprised at how muted the Big Twin sounds as you relish its lilting idle. Get the show on the road, and at part-throttle in lower gears running at slower speeds, the ECU will figure you’re in an urban environment, so makes the valves work in concert with one another to muffle the sound of the Twin Cam 96 motor - depending on the mapping, either one valve or the other will shut, or sometimes both.
Old Feb 5, 2008 | 09:14 AM
biz44's Avatar
biz44
ORIGINAL: Ridewva
ORIGINAL: capnron
No....the US bikes do not have this active valving in the exhaust or intake. If they did, then the after market exhaust co's would have had to address this.....at least for any ex system that changes out the part of the stock exhaust that houses this valve. They could have come up with some sort of electronic doo dad that would fool the ECU into thinking that the valves are connected and working properly so the bike dont throw a code and/or go into limp home. mode.....no? I see no reason for the MOCO to incur the extra cost of installing a EU spec exhaust on a US spec bike that does not have to meet the same requirements.
roscoe2010
Jan 6, 2013 07:25 PM
scottharstad
Feb 12, 2008 02:04 PM
gez45
Nov 13, 2007 03:01 PM
bobby5
Apr 21, 2007 07:08 PM
Longhair4life
Nov 15, 2005 10:17 AM
