Muffler Baffles ...
Old Jan 29, 2006 | 09:23 PM
Axholio's Avatar
Axholio
Default Muffler Baffles ...
I have this also posted in the Dyna forums and haven't gotten any replies after about 45 hits so I thought I'd try it here. Sorry for cross posting. Please be gentle...
My Neice and Nephew both have reciently gotten Dynas. He pulled the baffles out of the stock exhaust. I know it reduces back pressure and lessens HP somewhat, but since he did nothing to adjust the carbs (or anything else) what problems might this cause?
Thanks
Mike
Old Jan 29, 2006 | 09:30 PM
Johnny's Avatar
Johnny
Default RE: Muffler Baffles ...
bike might run a touch leaner
Old Jan 29, 2006 | 09:31 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
He's probably gonna be running lean. Just like when you put on some better breathing aftermarket pipes. He needs a rejet. Check his plugs and see how they look.
Old Jan 29, 2006 | 09:50 PM
wa state rider's Avatar
wa state rider
With the risk of being repetative (I posted this in another forum) Here is what I do with the stock mufflers. After pulling the insert out, purchase some 1-3/4 inch exh pipe tubing (got mine from the local NAPA store) and cut to the same length as the originals. If needed, tune the sound by drilling a few 3/8 holes in the tubing (optional) and insert them into the original housings (one small tach weld holds them in). Then pull the carb and increase the pilot jet 1 size and shim the main jet needle about .010. Also remove the idle jet plug and increase the setting for the best warm (not hot) idle. Mine is set up this way and I get 42 mpg on the hiway and about 30 in town if I don't rod it too much. Sounds bitchin and runs perfect.
Ride hard and safety first.
Andy_Mac
Jun 3, 2017 02:40 PM
RubberToe
EVO
13
Feb 21, 2016 07:48 PM
Missouri_Ridge_Rider
Aug 9, 2007 04:13 PM
TJ461vs
May 22, 2006 05:47 PM
T Tommyt
Jul 28, 2005 12:34 AM
