Good thing its a tube type tire. There is nothing to worry about if it didn't get to the tube. With a tube there is no chance of a tread seperation. Don't worry about plugging the hole or any other repair. You've done all you need to do...remove the screw. You're good to go. Just ride no worries!
For me, would depend on the life left on the tire. If it were a relatively "new" tire, I would dismount the tire, put a tire patch over the hole, remount it and run 100+ w/o batting an eyelash. I would not try to plug it,(if you have tube)because you have to run the scrape awl into the tire to clean the hole prior to plugging it, then run the eye hook with the plug into it also. If the tube was not ruined B4, it is now. And the first thing I would have looked at, is the size of the screw. If it were a 6 or 8, not sure I'd really do anything. But a 12, that's a decent size hole. JMO tho.
It is a tubeless tire on a cast wheel, and the hole is on the road surface, not the sidewall, service manual says replace if - puncture, cut, or other damage to the tire that cannot be repaired. Well, either way, new tire on order from chicago hd for $HD, was less than I expected. I'll be grounded a few days, but better that than the alternative. Thanks for the advice. I guess I got screwed...
Tire is pretty much brand new - 3000 miles - no tube, screw was pretty small barely in there, but definitely put a pinhole in the surface, but cannot see any belt thru the hole.
ORIGINAL: Da Gumpmeister
Look closely at the tread on your tire (car tires too), bet you have more than 1 hole that size in it. If it didn't penetrate the tubeI wouldn't worry about it. If it did i'd patch the tube and roll on.You run over things all the time that poke small holes in the tread, nothing to be concerned about. If it's in the sidewall thenI would be concerned and replace the tire. A hole in the sidewall will jeopardize the integrity of the tire.
