Clutch questions
Old Apr 13, 2008 | 10:41 AM
bigwhisk2's Avatar
bigwhisk2
6th Gear
Default Clutch questions
I want to purchase my 1st Harley. I was born missing the fingers on my left hand. I have plenty of grip just not enough length to grab and pull the clutch. I've seen several products available to reduce clutch pull considerably. Has anyone come across someone with a similar situation to mine and how are they riding? I know that I don't want a jocky shift setup. What about a twist clutch? Please help as I want to ride SOON.
Old Apr 13, 2008 | 11:50 AM
paulies 07's Avatar
paulies 07
Default RE: Clutch questions
I dunno, wow, might want to check with your local dealer, maybe they canswitch the clutch and brake levers or something, I wish you the best of luck.
Old Apr 13, 2008 | 11:55 AM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
Wow, good for you.
Apparently you already know about the EZ-clutch. My wife has that on her Wide Glide and it helps a ton. It's this, takes about an hour of shop time to install it I think:
http://www.debrix.com/items/item.aspx?itemid=1494074
I believe that there are different models for different years, but that's the idea.
I don't know any real good answer for you - hope someone here knows.
Don't give up.
Old Apr 13, 2008 | 11:56 AM
zukeeper's Avatar
zukeeper
move the clutch lever to the right side of the bar and put a proportioning valve into your foot brake to run the front and rear together
edit: jockey shifts are pretty easy to get a long with if you set it up with a break over type foot clutch instead of the suicide type foot clutch
Old Apr 13, 2008 | 03:34 PM
stro1965's Avatar
stro1965
It'd be kinda tough operating the clutch and the throttle with the same hand though...that would take some getting used to!
Old Apr 13, 2008 | 03:40 PM
zukeeper's Avatar
zukeeper
ORIGINAL: stro1965
I ran into a guy that uses that set up , he seemed to get along just fine . I am sure there is an adjustment period but shouldn't be a big deal.
Old Apr 13, 2008 | 05:42 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I would get with your dealer about some reduce reach levers and possibly a hydraulic clutch set up or a reduced effort clutch kit. HD must have a fix for those with small hands and in cases like yours. Wish you the best of luck.
Old Apr 13, 2008 | 06:14 PM
gambler's Avatar
gambler
Check this out also.
http://www.pingelonline.com/eshifter.htm
Old Apr 13, 2008 | 07:09 PM
hdpearson13's Avatar
hdpearson13
go with a setup with a left foot clutch right foot shift and run both brakes off the front brake lever any mechanic can make you this setup and will be very simple.
Old Apr 13, 2008 | 07:29 PM
smitty901's Avatar
smitty901
They make a bolt on clutch that works like a snow moble or go cart.
Your bike works like a automatic but you shift it Mischlers HDin Beaver Dam WI has sold a few like that. so no need to even worry about any other modes.
