Spark Plugs
What kind of spark plugs and wires is everyone using? I have a 07 Night Train 96 inch with 5000 miles on it and want to change the stock HD plugs.
https://www.hdforums.com/m_342484/tm.htm
I tried to post this in the "Engine Related" section but I could not post.
http://www.harleyhelp.com/sparkplg.html. \\; Might want to check this out..says in part..Little known fact:
2005 and later Harley-Davidson EFI systems incorporate an "Anti-knock" feature that operates by reading the current resistance through the spark plugs.
The use of any other spark plug other than 'Stock' (6R12) disables the anti-knock feature.
(Yes, that means the Gold, Platinum and SE plugs will also disable this function) .
Don't know if true or not.
http://www.harleyhelp.com/sparkplg.html. \\;\\\\\\; Might want to check this out..says in part..Little known fact:
Good article, thanks!
Keep it stock.
As already noted, HD EFI systems after 2005 seem to be a "little picky" so why create a problem if none exists?
Krusr
All the crap about increasing power or MPG is just that, crap.
That's just my .02, do with it what you will.
