Question
Old Jul 25, 2008 | 05:55 PM
jagator's Avatar
jagator
Default Question
Dropped my Helmet today. I have always heard it should be replaced if that happens. Just wanted to some other views. I dropped it inside on carpet. Looks okay, but thought I would ask.
Old Jul 25, 2008 | 05:57 PM
thrillseeker's Avatar
thrillseeker
Default RE: Question
ive, umm, errr, dropped mine, and I still wear it.
&nbsp\\;
being that you dropped it on carpet, I wouldn't worry about it
Old Jul 25, 2008 | 05:58 PM
JacktheBagger's Avatar
JacktheBagger
I wouldnt worry too much about carpet ..
&nbsp\\;
I have always heard repalcing them every few years is good idea as well , but I have never done it ..
Old Jul 25, 2008 | 06:07 PM
wpgmbhd's Avatar
wpgmbhd
was your head in it ??
Old Jul 25, 2008 | 06:14 PM
Soft06's Avatar
Soft06
I did a little research on this subject. I was told that if your head was in the helmet (GOD forbid a crash) when it was dropped, then yes, replace it by all means. It's the FOAM inside that is damaged from the wreck, it will lose it's ability to absorb the energy ...not so much the shell, although it can lose it's integrity also.
In your case...on carpet, wear it, and ride safe, and ride often.
Old Jul 25, 2008 | 06:25 PM
omgtkk's Avatar
omgtkk
If I replaced my helmet everytime it fell of the saddle of my bike and hit the pavement I wouldn't be able to afford to ride.&nbsp\\; The question ius wether the styrofoam shell inside the outer shell cracked.&nbsp\\; Very doubtful in your case.
Old Jul 25, 2008 | 06:42 PM
BadBoyFLSTC's Avatar
BadBoyFLSTC
I drop mine every day.
Old Jul 25, 2008 | 06:47 PM
Bat's Avatar
Bat
unless you dropped it from a fairly high spot (no expert, just a thought - 4+ ft) and it landed on its crown\\\\\\; I wouldn't worry about it.&nbsp\\;\\\\\\; I could be wrong, but I think even if your head is not in it, it loses some integrity when it hits hard.&nbsp\\;\\\\\\; The design is to disperse the blow over a larger area and a strong blow will be sent to the styrofoam, which will compact some.&nbsp\\;\\\\\\; Again, unless high and hard, no problem.
Old Jul 25, 2008 | 06:50 PM
The Shute's Avatar
The Shute
You boy's have foam in yours?!?!
Old Jul 25, 2008 | 06:59 PM
jagator's Avatar
jagator
Thanks - I kinda thought as much. It was about wast high. It did land on the crown. Not going to worry about it. Thanks for the input.
