Clear coating bare metal?
Old Mar 22, 2006 | 10:34 AM
74_ironhead's Avatar
74_ironhead
Default RE: Clear coating bare metal?
thats cause if it gets a dent or ding it needs to be repaired you'll see where the work was done throught the clear
Old Mar 22, 2006 | 11:20 AM
Stucarius's Avatar
Stucarius
Not a problem. Either a Base Coat or a Urethane will take care of you just fine. Make sure you do multiple coats and wet sand in between just like a regular paint job.
Old Mar 22, 2006 | 02:43 PM
fxstcguy98's Avatar
fxstcguy98
I would check with a professional on this first. Bare carbon steel will flash rust in a matter of seconds. I'm sure there is some sort of chemical prep that will illiminate it. Primer is formulated to go over the flash rust, the clear may have adhesion problems over the rust, plus it will look off in those areas.
Bowhunter8607
Mar 22, 2015 12:27 AM
Uncle Bull
Powdercoat & Paint
Feb 6, 2014 04:59 PM
motordrum
Feb 20, 2010 07:07 PM
LooseMoose
Feb 3, 2010 06:53 PM
