starting problem 08 street gl
Old Sep 3, 2008 | 09:49 PM
t2008's Avatar
t2008
Stage I
Default starting problem 08 street gl
has anyone had a problem with starting after a ride. the bike cranks but sometimes it starts and sometimes not.
Old Sep 3, 2008 | 10:04 PM
jad's Avatar
jad
Listen closely when you first turn the ignition on. You may have a problem with the fuel pump initiation circuit. The computer lets the pump run for three seconds then it shuts down because the crankshaft rotation sensor is telling the computer that it’s not rotating. After the engine starts the sensor keeps the pump running. One very common problem is a loose ground wire under the seat just behind the tank. Check it first. Good luck.
brntkndll
Apr 25, 2018 07:39 PM
Rambo_1mo
Electrical/Lighting/Alarm
11
Dec 24, 2016 09:18 AM
02fx4dude
May 15, 2013 07:17 AM
adam31093
Apr 10, 2013 06:32 AM
mike_oh
Apr 20, 2008 11:06 PM
