Broken engine case
Old Oct 11, 2008 | 10:46 PM
FXDHippie's Avatar
FXDHippie
6th Gear
well..with no help from MoCO.....or dealer.I pulled the motor,brought it to a local qualified welder and had the case repaired...gonna put it in Tues. so I can do the Halloween Run on Sun.......thanks to all who tried to help
Old Oct 12, 2008 | 12:20 AM
krusr's Avatar
krusr
That sucks, I've never seen that before
Old Oct 12, 2008 | 04:03 AM
Roadjunkie1's Avatar
Roadjunkie1
Never heard of that problem before. HAs the dealer perfromed all your work? Do you have a log? If so, contact Moco! NOW!
Old Oct 12, 2008 | 06:02 PM
pittguy's Avatar
pittguy
Case mounts break and most are due to the owners! Like on a shovel or older,you just cant plop the engine in the frame mounts and expect the engine to sit 100% flush before even installing any hardware.The case perches sitting off the frame mounts will need shimmed then bolts installed and torqued. On a newer TC,it could be caused again by owner,worn rubber mount or loose or broken mount and a heavy rt hand at stop lights.Please tell me it wasnt in a burnout pit!Tell us alittle about the bikes history??Any alignment ever done?has vibrations been getting worse?What upgrades have been done since it was new? A welded case looks awful even if hidden,and if the weld looks great it scares the bejesus out of the next buyer.I doubt that anyone will hear your story and open the bank,so now is your chance to get those stronger aftremarket cases or use the remanufacturing by Hd and keep all the numbers legit.Or go with HD cases and send them yours.
Old Oct 12, 2008 | 07:12 PM
JDB's Avatar
JDB
Default Know what you mean
Riding today and noticed that the inner primary case is cracked on the top. Not as bad as yours but bad enough for me. At least it is on top and all of the oil didn't leak out.
Old Oct 13, 2008 | 08:24 AM
bagman1's Avatar
bagman1
+1......
XFXDX
Engine Mechanical Topics
Apr 3, 2022 09:33 AM
MilsurpShooter
Oct 29, 2018 07:20 AM
dw2169
31
Sep 8, 2013 01:18 PM
Readyfreddy77
Jul 18, 2010 08:14 AM
danmo
Feb 28, 2008 08:19 PM
