Ignition/timing adjust for pipes only???
Old Mar 29, 2006 | 01:10 PM
yodal's Avatar
yodal
Default Ignition/timing adjust for pipes only???
Is it really necessary to need to adjust the ignition / timing for only having pipes and new air filter on a 05? If that’s all that’s done to the bike and the pipes are of equal length (keeping the Volumetric Efficiency the same between each cylinder) wouldn’t the Techlusion be just fine if no other upgrades were planned?
Old Mar 29, 2006 | 01:13 PM
Taildraggerdave's Avatar
Taildraggerdave
Default RE: Ignition/timing adjust for pipes only???
No it is not. The DFO/TFI is perfect in this application. I am very happy with mine.
Old Mar 29, 2006 | 02:20 PM
yodal's Avatar
yodal
I think this is the direction I'm headed for. I don’t intend to break the engine open for another two years at least. I found a stealth DFO for $165
Old Mar 29, 2006 | 02:53 PM
Taildraggerdave
That's the one I got. It installs in under half an hour. The settings they give are slightly rich, but will definitely give you a starting point. I still think the best part about this unit is the fact that you can take it back off the bike in the same half hour if it needs to go to the stealership for any warranty work. No chance of getting a denied claim because of any downloads or ECM mods.
Cowboy812
EVO
24
Sep 8, 2018 07:59 AM
bobupbob
Exhaust System Topics
Oct 28, 2012 11:06 AM
JohnK-NJ
Sep 2, 2008 06:41 AM
gigiflip
EVO
May 29, 2008 01:00 PM
socobandit
Ironhead
Jan 15, 2007 01:43 AM
