Cooler Running with 87 Octane???
So are you suggesting a lower octane fuel ignites and burns at a lower temperature and thus produces lower engine/head/exhaust pipe temperatures too???
Maybe that's what I'm noticing.
I'm still trying to figure out how diesel technology got into the conversation. Thems is two completely different ways of doing things, and no way to compare the two. And dont even talk similarities, cause there aint none
87 octane burns faster and earlier. Despite how advertising makes people think that 93 is "high test" or "premium", 87 is actually a better fuel. Provided the temperature and compression of the cylinder doesn't require a higher octane.
They also put some cleaning additives in some of the fuels to help justify its increased cost.
Try to tell someone this that puts 93 in their Mercedes because it makes them faster and they will laugh to death.
With some people, the more stupid they are the more that they think they're smart
Wait..............wait...............wait......... .......I think I'm one of those people!! LOL!!
As far as knock sensors, the motor will still knock a few times before the computer can retard the timing. Just like the traction control on my Charger. I can still smoke the tires for 3 full seconds before the traction control kicks in and stops me. (it's nice that they put a button on the dashboard so I can turn it off and smoke out my whole street)
Lower octane requires less air to burn completely and would combust better under normal conditions. Thus, creating more horsepower. Under normal conditions, 93 octane fuel very well may not fully combust. If your vehicle is not engineered to run high octane fuel then running 93 can actually harm the engine.
Based on that conclusion, I think it would be safe to assume that running 87, if you don't get any knocking, is just plain better for your motor in every single way imaginable.
My bike calls for 91 octane. We don't have that here. 89 or 93, those are the choices. It is freakin hot down here so maybe I'll run 93 in the summer and 89 in the winter, provided I get no knocking.
Still fun though
http://www.youtube.com/watch?v=0qgEGFxTfDw
Still fun though
Several things can cause detonation. The uncontrolled burn of the AF mixture, read that EXPLOSION. Not good.
Pre-ignition is one of the things.
Pressure is another. Read that, 'compression'
That is also what allows John's diesel tractor to fire with that 'syrup' being injected into it. Heat of Compression.
The TPV equation. Temp, Press, Volume. For this scenario, it is T= P/V. The piston goes up, Volume decreases, Pressure increases, Temp goes WAY UP.
Touch the top of your air compressor when it gets done filling your air tank. That's "Heat of compression"
Octane 'controls' the flame travel in the AF mixture. The higher the octane, the higher the pressure needed to ignite it. Thus, use a higher octane fuel in a higher compression engine, to prevent it from igniting, due to heat of compression.
I do not remember the 2 ingredients used to determine octane, but the octane # is a percentage of one of those ingredients.
And as mentioned, higher octane does not translate to higher power.
You have to run whatever octane will prevent detonation. If 87 runs, then run 87. If it is knocking or pinging, up the octane.
You have prob'ly heard pre-ignition, if you have ever shut off the ignition, and the engine will continue to run on. That's caused by pre-ignition.
Will it run cooler? I am not 100% sure.
I have never tried this on a 'new' HD, but on cars, you can test the 'knock sensor' by rapping on the manifold next to the sensor and observe what the timing does. If I remember, I'll try that next time I have one near.
We just had a thread over in Sporty section, guy complaining of a 'shudder'. He posted the speeds he was sensing the shudder. It was 'detonation', from lugging the motor. He was basically riding his Sporty like his Big Twin. They won't 'lug' like a BT. Lugging causes very high pressures in the cylinder, thus the 'detonation'.
It will tear a motor up if you keep doing it.
Okay, go ahead, 'FLAME travel' away.
An old mechanic once told me "You don't mess with fuel"
