first 1000 miles. need advice
I hear that its important to "break in" a bike with ease, to go gentle on it or somethin at first. How true is this and what does it include? what should and should not do?
I plan on sticking with my neighborhood streets at first, but what would you recommend doing for on gaining experience, confidence and sharpening your skills when you first start riding? any good things to practice besides just riding around normal?
any other general advice on clutch control, braking, traffic, w/e, let me know. thank you.
Hit the search function. The questions you've asked are pretty common and there are hundreds of threads with good info for you already on the forum somewhere.
The first thing I would say is to take a good, full-on riding course. There seems to be a general feeling that riding a bike is as easy as just jumping on, sticking to local roads for while, and off you go. But people don't do that with cars. They take a proper training course to learn how to do it properly. Treat your bike the same way.
And have a great time!
What you want to do is get in a gear where it "pulls hard" without revving too quickly. From low throttle, but fast enough that you are not lugging, you accelerate wide open to about about 2/3 redline, roll off the throttle, let the engine slow down, and do it over and over again ten times.
Here's his actual directions, from American Rider. Note these are for a new rebuild, where the engine has not yet been run. Most, if not all, new bike engines have already been "run-in" at the factory.
1) Do not start the engine until you are ready to ride the bike.
2) After starting, quickly get out on the road and into third gear.
3) Accelerate at full throttle from 30 to 60 mph in third gear.
4) Close the throttle and coast back to 30 mph.
5) Repeat this full throttle/coast procedure a total of 10 times.
6) The rings are now seated and you can ride normally.
My understanding is what the above method does is creates high cylinder pressure, expanding the new rings tight against the bore, instantly wearing down the high spots and seating the rings. Rolling off the throttle creates vacumn which sucks oil up onto the bore, carrying off the shavings, which will end up in your oil filter. Breaking an engine in too easily can cause the glaze to build up in the "low spots" and rings may never seat properly.
Pick up a copy of "Ride Like a Pro" video, set up a couse like they show you, and do those excersizes.
Next year try the MSF-ERC class.... it goes over the same stuff as the BRC, but it's one day, and you're on your own bike. It will further sharpen those skills
As far as break in ? see reply #3
good luck, and welcome to the most fun you can have in public
Honestly after the video, taking the MSF course was pretty pointless, I was surprised at the things that WEREN"T taught in class (i.e. trail braking while in the friction zone).
Congratulations, be safe and have fun!
My only addition after my years on the bike is to keep a safe following distance. It really does no good to tailgate a cage - it limits your sight of the road, obstacles, etc and generally gets you wherever you are going no faster than if you drop back a bit and give yourself some room.
Congrat's on te bike - have a ton of fun.
1. take your time and practice, practice, practice especially in parking lots.
2. no 2 up until you have at least 1000 miles in and feel confident in your ability
3. start with short rides and go progressively longer if that feels better.
4. re-read your msf course materials until you know them
5. Never feel like you need to keep up with someone elses level of riding..go at your own pace
Breaking in a new bike:
1. follow the owners manual recommendation for speed/revs vs miles
2. I change oil at 100, 500, 1000 miles
3. if you can heat cycle your engine (short 15-20 minute rides followed by complete cool down) for 2-300 miles it is a good idea. But not a must.
4. I break in the bike for 2000-2500 miles before I will redline it.
Good luck.......ride safe always. BTW, I do recommend you wear a quality helmet.
Welkum to the Zoo, Roadkill.
ALL good advice so far.
The one thing I'd really like to add, high speed PANIC stops. When you are on a nice. long stretch of open hiway, NO traffic around, pretend someone pulled out, or something fell off an imaginery truck. Practice panic stopping, so you learn the point where your brakes begin to lock up. Learn to stop as fast as humanly possible, and still maintain full control.
The time to realize you are not sure, is NOT when that chunk of plywood falls off the truck in front of you, or the cage pulls out.
Always give yourself plenty of maneuvering room/space. Most ppl run out of time, long B4 they run out of ideas.
For your 'fresh' motor, go back, and memorize MnPGR's post. That's exactly what I tell ppl when they head out with a 'brand new' rebuild.
I also suggest they use dino oil, for break in. Not as 'slickery' as synthetic, and will help with the 'break in' and to seat the rings.
Also, as KB, said, change at 100 or so, 500 or so, and 1000 or so. If ALL looks and runs good, then you can switch over to syn, if you like.
What type motor do you have? If shovel, or older, I recommend 50w unless it is going to be over 95* consistently, then 60w.
Again, Welkum, ride SAFE, and keep on postin'. Glad you're here.
