HD fuel gauge..., useless!!!
Old Oct 11, 2008 | 09:08 PM
riteowaysmcvp's Avatar
riteowaysmcvp
Originally Posted by Mr Zip
my SG gets 100 miles pegged at full, then the next 50 miles to half tank (according to the guage), then at 1/4 tank you better find a gas station. I dont even really use it. I reset the odometer every time I fill up and just go off of that.
Mine is just like that. I will have to see if I can adjust it.
Old Oct 11, 2008 | 09:09 PM
dFREDb's Avatar
dFREDb
Originally Posted by Mr. Lucky
Mine seems dead nutz on - guess I got lucky.
Same here. Reliably kicks the low fuel light on at about 1/8 on the needle or around 178-185 miles. I've ridden with no gauge for years on other bikes so it's just a little added convenience.
Old Oct 11, 2008 | 09:10 PM
url8's Avatar
url8
Mine on my 07 Deluxe was very much the same...inacurate. I went with the flush mount caps and the LED's seem to work well however, I'm on my second set!!
Old Oct 11, 2008 | 09:55 PM
Rabbit_'s Avatar
Rabbit_
Me too...
Old Oct 11, 2008 | 09:58 PM
wildman67's Avatar
wildman67
Mine only work"s when it is full, and when it is empty!
Old Oct 11, 2008 | 10:15 PM
Cold Rider's Avatar
Cold Rider
Never use the guage. Can't see it anyway. Always reset the trip meter at fillup. Looking for gas at 150 miles more or less.
Old Oct 11, 2008 | 10:41 PM
Roadjunkie1's Avatar
Roadjunkie1
Originally Posted by SoftTailTim71
I managed to ride for 20+ years without fuel gauges on any of my bikes. So, now my '06 FXST comes with one..., I was like "cool, a fuel gauge. No more waiting to turn the reserve tank on at 60mph anymore".
I tell ya, this thing ain't worth the chrome plastic it was made with. It only measures the top half of the tank. I fill my tank, ride 200 kms (anout 85 miles) and the thing is buried under the "E". I can go 320 kms before needing to switch to the reserve tank. Does "E" stand for "enough" on these things?!?
Are they all like this, or is mine just outta whack?!? I suspect that maybe because my bike is lowered in the back, it may be throwing the thing off a little. And no..., I have no intentions of raising my suspension to correct the problem
I rode for years without one also. Now own a Roadglide, it has all the whistle and bells and has made riding a much more enjoyable experience. My fuel gauge, oil press guage, volt meter has worked flawlessly over the years. I still make it a point to stop and top off the tank every 100 miles or so when I am on the road, but it comes in real handy in the city where I might fill once a week.
If it's not working then there is obviously a problem that your not familiar with. Do you own a service manual? Keep digging, you WILL find the problem.
Old Oct 11, 2008 | 11:05 PM
itileman's Avatar
itileman
I've had 3 HD's and the fuel guages have been dead on.
Old Oct 11, 2008 | 11:16 PM
MidnitEvil's Avatar
MidnitEvil
I use the trip meter, but, I suppose the fuel gauge is pretty accurate in indicating the level in my main tank.
Old Oct 12, 2008 | 12:21 PM
Stretchman's Avatar
Stretchman
Instructions for using the Harley tank guage.
Fill up. The guage is pretty reliable when the tank is full.
Ride out. The guage will stay on full for awhile, at least an hour or more, indicating you are not going to need to stop until at least the next station, 72 miles down the road, because, hey, you're guage says full up.
As the exit disappears in your rear view mirror, you will then begin to notice some activity. This activity is visible, and the guage will readily indicate that you are no longer full.
Only 68 more miles to go, and already you're down to half a tank. But half a tank is 2.5 gallons, right?. So, you'll be fine.
Then at only 40 or so miles away, your guage will be decidedly in the red. Now, you're cursing yourself for not stopping. Then, almost at 20 miles, the almost too far to make it yellow light comes on. Now is the time to panic. Draft yourself behind the mail truck. Look for people you think will be willing to stop and help you. Don't trust them.
Coast down the exit way, and pull into the station. Be surprised when it only takes 4.6 gallons. Force some extra in. Cap off, turn the key, and watch the guage climb back up to the full mark. Watch the yellow light go out. Repeat.
And remember, if Harleys were supposed to come with a real gas gauge, they wouldn't have made one out of spare gas cap parts.
Stretch
