HD fuel gauge..., useless!!!
Old Oct 13, 2008 | 10:17 PM
  #41
daneman27's Avatar
daneman27
My brother has a 07 night rod and he is already on his 3rd fuel gauge. You think they could improve their product a little.
Old Oct 13, 2008 | 11:52 PM
  #42
SoftailBrian's Avatar
SoftailBrian
Mine says empty after about 50 miles. I thought I just got shjtty milage.
Old Oct 14, 2008 | 01:56 AM
  #43
biz44's Avatar
biz44
Originally Posted by HoggyMtnBreakdown
You should also have a reading on the odometer that tells you how many more miles (kilometers) you can go on what's left in the tank. Between that and the fuel guage you should be able to make a fairly accurate estimate.
Not on the softails.
Originally Posted by Dustball
That's funny!
but very true!
Originally Posted by JKK
I think a lot of models use a similar float, easy to calibrate these if its way off
when mines on E I got just a lttle less than a gallon left
light comes on a little before that
if yours is that far off you could pull the tank unit out and bend the arm gently
Exactly. The thing is that when you working with a 4.5 gallon tank a small bend in the float arm could change things quite a bit. If I was planning on making this adjustment, and I may because the gauge on my 03 is 50/50 at best. I would drain the tank until there is exactly .5 gallon in it, then set the float arm so its just hitting E. I guess w=once the temps start hitting the 30's I will pull it apart and start adjusting.
Old Oct 14, 2008 | 02:20 AM
  #44
Mad Mike's Avatar
Mad Mike
Way I figure it, if Harley didn't put that stock piece of crap on there, there wouldn't be an excuse to flog all the after sales replacements. Gotta look at it from the perspective of the average Harley rider bein' of an age that probably needs reading glasses just to see that tiny guage anyway. Then they also position the little window so that nobody can see it at a glance from a normal riding position either. But, the good news is, for an extra $140-200 you can buy a range of replacement caps with all kinds of flashing lights. Almost diabolical wouldn't you say
Years of just flippin' the reserve petcock and now that I'm at an age were short term memory starts to become a problem, I gotta try and remember to reset my trip odometer every time I tank up Wouldn't ya just know it
Old Oct 14, 2008 | 06:21 AM
  #45
Chrizzby's Avatar
Chrizzby
I blame the biker for not knowing how far he has traveled, & not checking his milage.....
Old Oct 14, 2008 | 08:58 AM
  #46
eaheritage's Avatar
eaheritage
my 04 heritage gage is useless to ,,like most i go by miles
Old Oct 14, 2008 | 09:29 AM
  #47
Toolguy's Avatar
Toolguy
Originally Posted by Stretchman
Instructions for using the Harley tank guage.
Fill up. The guage is pretty reliable when the tank is full.
Ride out. The guage will stay on full for awhile, at least an hour or more, indicating you are not going to need to stop until at least the next station, 72 miles down the road, because, hey, you're guage says full up.
As the exit disappears in your rear view mirror, you will then begin to notice some activity. This activity is visible, and the guage will readily indicate that you are no longer full.
Only 68 more miles to go, and already you're down to half a tank. But half a tank is 2.5 gallons, right?. So, you'll be fine.
Then at only 40 or so miles away, your guage will be decidedly in the red. Now, you're cursing yourself for not stopping. Then, almost at 20 miles, the almost too far to make it yellow light comes on. Now is the time to panic. Draft yourself behind the mail truck. Look for people you think will be willing to stop and help you. Don't trust them.
Coast down the exit way, and pull into the station. Be surprised when it only takes 4.6 gallons. Force some extra in. Cap off, turn the key, and watch the guage climb back up to the full mark. Watch the yellow light go out. Repeat.
And remember, if Harleys were supposed to come with a real gas gauge, they wouldn't have made one out of spare gas cap parts.
Stretch
I have the six LED light gauge. It's not good. Most fill ups (I mean filled up) the LED's will show 4 lights (2/3 full). Occasionally six. It goes down in two's. So it will go from 4 to 2 then red. It's nuts. I really need to have my wife follow me with a gas can in the car and run the tank dry. Then I'll have a better idea of the fuel range and see if anything "resets" on the gauge.
Old Oct 14, 2008 | 09:53 AM
  #48
sofadog's Avatar
sofadog
My 07 UC gauge has a mind of its own, never the same whenever I ride. I always reset the tripmeter at fill up and start thinking about refueling around 160 miles with one gallon left.
Old Oct 14, 2008 | 10:09 AM
  #49
cadman311's Avatar
cadman311
My dyna Lowrider tank is off by couple gals. But the Road Glide will get me right down to the last drop of gas. I think a 5 gals fill up is great timing.
Old Oct 14, 2008 | 10:19 AM
  #50
Mad Mike's Avatar
Mad Mike
I figgered it out boys - 2 and a half hours is about all I can go without havin' to pee and when I'm out travelin' that's also about the amount of time before I'm thinkin' it's time to fill up again
