I need help!
Old Apr 1, 2006 | 01:34 PM
Renegade's Avatar
Renegade
Default I need help!
My 2006 FXDLI has been giving me a problem. When I pull in the clutch in anticipation of downshifting before executing a turn etc. the engine will simply die. I took it to the dealer once before and after three days they could not determine what the problem was. It ran fine for about 200 miles and then started doing the same thing again yesterday. Has anyone experienced this problem? If so, and you have an idea why this is occuring, I would greatly appreciate any insight. Hope to be riding confidently soon as spring is almost here!
Old Apr 1, 2006 | 01:39 PM
KBES BAGGER's Avatar
KBES BAGGER
Default RE: I need help!
Are you FI? If so have the stealer check the MAP sensor and the wiring going to it. My buddy had his MAP sensor go bad and it would start/idle just fine but give it throttle it would die. Another buddy had his wiring rubbing on somthing underneith that caused a short, it acted alot like what you are saying.
KB
EDIT: Just looked again you are FI, have that checked out.
Old Apr 2, 2006 | 10:08 AM
MOking's Avatar
MOking
Find another dealer!
What kind of dealer has a safety issue with a brand new bike and not only can't fix it, but returns it.
I'd be on the phone with the H-D rep demanding a new bike under the lemmon laws if they can't fix it.
Old Apr 2, 2006 | 12:20 PM
vernh59's Avatar
vernh59
Sounds like a sensor going bad so it os an itermitent problem. They are the worst kind to fix because they absolutely won't reoccur when the bike is in the shop. The dealer may not be able to actually see the problem so it may take some time to find it. That said, they should be able to check everything based on your description of the problem. Probably something simple so keep at it. You will get it worked out.[&:]
jlasoftail
Aug 10, 2012 02:48 PM
GoSox92
May 31, 2011 10:21 PM
el campito
Nov 19, 2010 06:33 AM
01Ultra
Feb 21, 2007 11:53 PM
vheflin
Sep 10, 2006 12:05 PM
