Should be no problem if you just clean the connectors and see if that helps, if not than maybe try to get your dealer to mail you a new MAP sensor under warranty and install it yourself.
Other than that, if I was you, I would just go to the beach for the day and forget your problems (you lucky bastard...it's snowing here ya know!!!)
