I'll pay someone...
Old Oct 28, 2008 | 10:11 PM
MetalSpike's Avatar
MetalSpike
I installed the PCIII in back if the mud flap. The rest looks like the pics. Hope this helps.
Old Oct 28, 2008 | 11:06 PM
Deepsouth251's Avatar
Deepsouth251
I feel your pain. Just put a Smart Charger harness on my 09 Ultra today and the battery was a bitch to get to. Standing back looking at it I think I may have to put the power commander (whenever they become available) under the side panel and thread the wire harness up to the ecm if the wire harness is long enough. If not then someone will come up with a solution. They always do.
Old Oct 28, 2008 | 11:34 PM
OhioSkully's Avatar
OhioSkully
I feel your pain also, i did my pipes, stage I ac, and PCIII in my dyna and i tell you one thing its like the old saying goes trying to stuff 10 lbs of **** in a 1lb bag there is not alot of room in there i had mine in and out 2 or three times before i felt it was ok and after several beers and cussing and hrs i finally got it to where it was good
Old Oct 29, 2008 | 12:04 AM
dogtownmax's Avatar
dogtownmax
Originally Posted by Treek
... to come hook up this damn PCIII on my Nightster. For the life of me, I can't figure out how to fit it under my seat. Seriously... anyone in the San Francisco area who wants some beer, maybe dinner and $50 let me know.
piece of cake. no $50 needed, but a beer would be ok...
i live in oakland and would be happy to help.
Old Oct 29, 2008 | 08:55 AM
Treek's Avatar
Treek
I've got plenty of beer!!
Old Oct 29, 2008 | 09:08 AM
jefnightrain's Avatar
jefnightrain
I worked an entire weekend trying to fit my pcIII in my night train. I finally gave up & took it to an indy who did it. He says you just need to drop a bunch of Fbombs in there to get it to fit
Old Oct 29, 2008 | 09:19 AM
guitarman777's Avatar
guitarman777
That's funny right there.
Old Oct 29, 2008 | 10:50 AM
*NIGHT TRAIN*'s Avatar
*NIGHT TRAIN*
I had my PCIII installed and dyno'd by the Dynojet Tuning Center here...they put mine into the mount for the alarm system (didn't want one when I bought the bike)...snapped in like it was made for it...
Old Oct 29, 2008 | 11:01 AM
Mordrapheus's Avatar
Mordrapheus
Do you still have the Stock Seat?
if so you should be able to fit the PC under the ECM unit into the tray and then sit the ECM on top...the difficulty is the positioning the connectors such that you can get the seat back on.
However if you have an aftermarket seat, you prob wont be able to fit the PC under the ECM. Haven't looked at a Sportster in a while, so not sure if the Softail solution will work on a Sportster...on the Softails, the PC unit accually is installed (ziplined) inbetween the plastic rear wheel mudguard
... have a look at the softail installation instructions:
http://www.powercommander.com/downlo...eng813-511.pdf
not sure if that helps, or if its possible on the nightster but might be a possible solution
Old Oct 29, 2008 | 11:12 AM
Treek's Avatar
Treek
I do still have the stock seat. Like you said, the PCIII fits perfectly under the ECM, but its those damned connectors.
I think I just need to overhead said and unhook all the wiring, fit the connector in, then rehook everything.
I have bigger problems to worry about now though... I hooked the bike back up stock (ECM only), and now it wont even start. The security system is going crazy (blinkers flashing) and I can't figure out why. I had to drive the cage to work this morning which just makes me grumpy.
