Flippin' through an old JP catalog the other day I saw this and they still have it on their site...Only $7.00 for black and $10 for chrome. Just haven't gotten around to ordering it yet..
Never seen one before but looks like you could go to a modeling store and find a little "C" clamp of some type used for holding small parts and get the same result for less $$$. Just a thought.
Takes some getting used to but for $12 it's not bad.
As stated all it does is tighten up the star wheel making the throttle grip easier or harder to twist.
I had to play around with mine for awhile to get it so it would tighten the throttle enough when "on" but loosen it enough when "off". Still have a problem with it being tight enough to use as cruise control. Seems the throttle creeps back.
For the longest time I had a problem with my gloved finger accidentally hitting the lever. After getting used to it, it's less of a problem. Could be dangerous if you're not alert.
It never tightens the throttle so much that you can't manually twist it back.
I found it's main benefit is for long rides on flat terrain just to be able to relax your grip a bit or when for whatever reason you need to take your hand off the throttle.
