Would you use loctite.....
Old Nov 24, 2008 | 11:16 AM
eddie31770's Avatar
eddie31770
Default Would you use loctite.....
On HD Trim Rings? If so which one?
Old Nov 24, 2008 | 11:23 AM
honestbob's Avatar
honestbob
Locktite isn't a glue, its a thread adheisive might be better using some type of weather strip glue or something like duco. My .02
Old Nov 24, 2008 | 11:36 AM
JW1200's Avatar
JW1200
If you deceide to use loctite use the blue.
Old Nov 24, 2008 | 11:38 AM
elvis240sx's Avatar
elvis240sx
I wouldn't use lock-tite, they are just little bitty screws
Old Nov 24, 2008 | 11:52 AM
ngoti8tor's Avatar
ngoti8tor
If you don't plan on taking the trim rings off often (no reason to), then I would use Loctite.
Since the screws are small, I would use Blue (removable) Loctite on them.
Old Nov 24, 2008 | 11:58 AM
d_slat's Avatar
d_slat
+1, i'd use the blue
Old Nov 24, 2008 | 12:38 PM
Tinkermc's Avatar
Tinkermc
i
I would use it but I suggest the blue and don't forget to shake well.
Old Nov 24, 2008 | 03:16 PM
GlennA's Avatar
GlennA
+1 on blue. If I remove a screw or bolt, it has blue on it when it is reinstalled. I have lost plenty of hardware in years past on numerous bikes. Blue is insurance.
Old Nov 24, 2008 | 06:21 PM
vet767's Avatar
vet767
Use blue on most things, but am not opposed to red on big bolts. A little heat will help to remove stubborn ones, a soldering gun for blue and small screws or a pencil torch for the big stuff. The right wrench constant pressure and a little heat will work wonders
Old Nov 24, 2008 | 08:19 PM
HSdropout's Avatar
HSdropout
I use black silicone on small stuff...it stays put but can be removed easily
DocD1
Detailing
24
Aug 8, 2017 07:02 AM
GCJohnny
Harley Davidson Videos
Jul 9, 2017 05:54 PM
SmokinLoon
Detailing
11
Nov 3, 2013 12:05 AM
Z
Oct 25, 2008 10:16 AM
chrism84
Detailing
Dec 5, 2006 01:29 AM
