Oil Coolers
Old Jan 3, 2009 | 07:27 AM
FLHXXHLF's Avatar
FLHXXHLF
I've been interested in an oil cooler sense i've got mod's done to my bike. the problem is finding one that's efficient. I really don't see how that little cooler does the job, especially where it's at. I seen a guy on ebay that has water proof fans you can install with the cooler for heavy traffic.
In my opinion, I feel the oil cooler needs to be bigger and have a fan hooked to it for optimum performance and cooling. I might be wrong there . I also think placement is important. Im guessing most harley people don't want to be caught dead with a radiator on their bike, and you have the looks issue also. So im still looking for what i would consider an efficient oil cooling system. Jagg has some universal coolers that are pretty big but i would have to modify the mounting brackets. Just my two cents.
Old Jan 3, 2009 | 07:36 AM
FLHXXHLF's Avatar
FLHXXHLF
I found this. I think this is the ticket. If it only had fans. Im a little cautious about it being under the bike but it's a great idea.
http://budsbikerparts.net/
Old Jan 3, 2009 | 08:16 AM
Da Gumpmeister's Avatar
Da Gumpmeister
Originally Posted by hpfatboy
Never gets HOT enough up here in the NORTH, to even think about an oil cooler. Guess it all depends on where you live. Wish i had your problem, i mean the nice weather and the warmth.
Well, we have a 'WINNER,' IMFUO.
We actually take them off, if on a used scoot.
BUT for you folks that run 'down sowth', desert, or in heat and high humidity, you NEED all the help you can git. (COOLING the oil, dummmies. We CAN'T do anything 'bout the rest!!!!!!!!!! )
In my case, I run 50w until July and August, then pour in 60w when it gets 'warm'.
IMHO, the 'jury' is still out with the 'new' motors. We may need a cooler on them, even up here. The death nail for an air cooled engine is heat. It is what killed the VW Beetle in this country. As the EPA steps up more and more emmissions control, more and more heat is built up/retained in the motor. That's why VW went to h2o pumpers here, but the air cooled is still made in Mexico.
Which cooler works the best? I'll jus' git my popcorn and sit back and watch the goings on.
The Formula you need to work with, is: Q = M X delta T. Q = heat, M = mass flow rate, delta T = difference in Temp, in and out.
I happen to have some of those "Mother's helpers" (worry killerz )for oil filters. They are rings, that look like an accordian bellows, but in a circle. You stretch it over the oil filter, and they 'increase' the surface area exposed to the air, and thus transfer heat from oil filter to air. Do they work? Elephino. But they sold 'em back before a lot of you were born.
One of those 'gadgets' that a guy ends up hangin' on the grudge wall, and then peeps ask silly ?'s about 'em, when they are hangin' out for coffee. You know, like 'deer whistles'. IF you believe, you believe.
I believe I'm gonna git YET another cup o' coffee.
Old Jan 3, 2009 | 09:12 AM
jimmers1817's Avatar
jimmers1817
Don't think I want to stick a $550 piece of fragile equipment on the bottom of my bike.
I'm more interested in where he got that backrest for that Deluxe. Best looking one I've seen yet.
Old Jan 3, 2009 | 09:56 AM
16X9 Shooter's Avatar
16X9 Shooter
Another option.
http://billetcool.com/
Probably helps a little. Definately makes it easy to change oil filter without making mess.
Thing I don't like is cannot run K&N filter with it...filter is too long. '06 RG.
Old Jan 3, 2009 | 10:25 AM
softail04's Avatar
softail04
don't se a need for a cooler on my bike and I ride in so cal and az both..
if I wanted a radiator looking thing on my bike I would have bought a metric.
Old Jan 3, 2009 | 10:28 AM
JaronB's Avatar
JaronB
That's the way do go because I don't like seeing the extra bulk. But for 600 bucks got other money priorities first. I'll get one the day I get a full dresser and move to vegas
Old Jan 3, 2009 | 01:36 PM
3dogsgulfcoast's Avatar
3dogsgulfcoast
6th Gear
Default oil coolers
I ride alot, and usually hard, besides it wont hurt to have cooler oil,sometimes we all get caught in stop and go traffic, ive seen plenty of harleys on the side of the rode cooling off going to Daytona.its a riders choice! It cant hurt.
Old Jan 3, 2009 | 06:07 PM
NOLAMike's Avatar
NOLAMike
I too ride on the Gulf Coast. I installed the HD oil cooler with the built on thermostat last summer. My bargain basement thermometer (the inside of my thigh) tells me the engine runs cooler now.
Old Jan 3, 2009 | 07:48 PM
streeteagle's Avatar
streeteagle
The tech guy in AR magazine says if you run synthetic it's good to 300 degrees, you don't need a cooler. So....
