Front brake issues
https://www.hdforums.com/forum/frame...reak-pull.html
Don't know if it's related to your problem or not but might be helpful....
Good luck for sure.
Good luck for sure.
thanks for the redirection. I am new to here and didn't realize there was a brake section. Read through them and am going to try the piston cleaning trick. thanks again and happy riding.
That's where I usually run into trouble, more often than not. I usually fill the front backwards. In other words, pump the fluid in via the bleeder, using a Mity Vac to accomplish this. But that is no guarantee that the master cylinder will be 'air free' when done. Sometimes I will have to remove the brake line, and 'bench bleed' the master cyl on the scoot. Then refill from bottom to ensure the system is full.
But if you can 'pump it up', and it will hold firm as long as you pull on the handle, IMFUO, you still have air. IF it were STILL your master, it would slowly 'bled by' and your lever will eventually 'bottom out'.
NOW, why did it work when you did the rubberband trick? When you 'pumped it up', you were applying 1000's of # of pressure to the fluid. Then put a rb on their to 'hold' that pressure. It literally forced the air 'back into solution' (fluid). You started riding, the air started coming back out of solution when the pressure was released. Jus' my guess, tho.
My bike is an 02 RK also and I have the same problem. tried the caliper cleaning trick and got great results the first time. am about to leave for sturgis next week and thought I'd do it again because my lever feels a bit soft. didn't get the same results this time. don't know what else to do, I've bled the crap out of my brakes and if there's air in there, I don't know where the hell it is. I'm at the point where I'm thinking about getting new calipers.
let me know if you find a solution.
