Camping gear
IMHO, no need for a chair; never carried one on any of my bike/camp trips.
As for cooking, not much better than an old fashion Cowboy Oven, also known as a Dutch Oven. The Cowboy or Chuckwagon version has three legs, a wire bail handle, and a rimmed lid so that coals from the cooking fire can be placed on top as well as below. Make sure the lid is concave so the coals don't role off. I've seen some cheap imitation Cowboy Ovens that have a flat lid and I have no idea how a fellow keeps his coals on top. By having coals on top and bottom you can get a more uniform internal heat. I use Match Light coals which can be purchased just about everywhere during the summer months.
It is amazing what you can cook with these things. You can get 10" and 12" ovens, and I prefer the 10" for taking on the bike. You can buy a plastic case for them as well, but I just pack mine in a towel. The 10" versions fit easily inside the saddle bag along with my utensils and shave kit. An Aluminum oven weighs around 3 pounds while the cast iron models will go about twice that weight.
The beuty of the Cowboy Oven is you can cook pasta, potato, meat (beef or chicken usually) and when I'm especially fired up (pun intended) a desert right in the same oven.
I've also been a "foil oven" cook over the years. This method doesn't use a pot/pan/oven but uses aluminum foil instead. It's amazing how much you can cook with a little meat, a few vegatables, some worchister sauce or other sauce and some foil. There are lots of spots on the web with recipes for both Cowboy Oven and Foil Oven cooking.
Okay ... here are a couple of my Solo-Trip recipes ...
Cowboy Oven Hens in the Pot
1 Cornish Game Hen
1 Potato
1 Small onion
1 small can corn
Seasoning (see below)
Virgin oil or vegatable oil
1 cup water
Start coals in pit and allow them to turn ashen. Warm CO and slightly coat bottom with oil (not too much). A little oil on your bird (so that it doesn't brown too quickly) and put it in the pot. Let the hen start browing on at least two sides.
Slice potatoes and onion. When bird is slightly browned pour in corn and water. Toss in potatoes and onion. Cover and put a half-dozen coals on lid. Allow to stew until potatoes are tender. Whole meal cost less than $5 and cooks in less than an hour.
Ketchup Pack Surprise
5 Packs of Ketchup from your local burger joint
1/4 to 1/2 Lb ground beef (how hungry are you?)
1 small potato
1 small pepper (green or red work well)
Small can of Ranch Beans
Start your coals (15 to 20 is usually enough). Crumble ground beef into pot while it heats. In the meantime cut potato and pepper into slivers. As beef starts to brown add packets of ketchup. When beef is "popping" add potato then pepper. Let steam for less than minute. Add beans (do not drain) and cover with lid. Add half of coals to lid (cools meat at bottom and starts uniform heat).
Best part of these meals is that if you know your own appetite and don't overbuy you'll have zero leftovers for the bears.
