primo brute 3
Old Apr 24, 2013 | 08:25 PM
fast99's Avatar
fast99
Default primo brute 3
I am looking at installing a primo brute 3 the question is the ring gear there is a 84 tooth and 102 tooth listed my bike is a 99 fxstc evo which one would I need to get?
also anybody run one of these belt drives?
Old Apr 25, 2013 | 09:38 AM
2006FLST's Avatar
2006FLST
The only difference in the 102 versus the 84 is the pinion gear size. My BDL is an 84 tooth but it came with a new pinion gear which is simple to swap out. I looked on Primo's site and they offer both the 102 and the 84 for our bikes. If you notice the 84 comes with a 10 tooth pinion gear.
Also I was looking at the Brute 3 extreme enclosed on their site. If I am wrong on my comments above hopefully someone will correct me!!!
Old Apr 26, 2013 | 12:46 PM
fast99's Avatar
fast99
when I take the cover off I will have to see what is on the bike now
Old Apr 26, 2013 | 02:00 PM
2006FLST's Avatar
2006FLST
The main thing is to make sure the starter pinion gear and the ring gear match up. That is all that matters. If in doubt give Primo a call but I think you are fine either way. One way just means you have to swap the pinion gear.
Old Apr 26, 2013 | 08:35 PM
fast99's Avatar
fast99
how do you like the beltdrive? you feel any difference the way the bike rides
Old Apr 27, 2013 | 11:31 AM
2006FLST's Avatar
2006FLST
Not really. It is a little more jerky if that makes sense. There is no compensator like on a chain but i like it. very solid feel. But for me I had so many issues with my chain from a bad basket to leaks I could not stop even with new gaskets that I swapped. But I have owned primo's and BDL's before so I was happy to swap. They are easy to maintain/inspect etc. But YOU MUST install them properly and align them properly and they will last. I also leave my derby and inspection covers open so it is obviously louder but I love that. One thing I will say is make sure you really clean up good before you swap. You will be amazed how much fluid will keep showing up. Also you may want to go ahead and put a new crank seal in with the spring facing IN. This will help keep oil out of the primary. And the last thing is even though these set ups are supposed to be a direct swap there is a great change you will have to grind down spots inside your covers or else it can interfere with the belt pulleys moving.
LQQK_OUT
Jan 11, 2019 02:48 PM
revnrob
Feb 25, 2014 03:48 PM
raiderluke402
Dec 27, 2011 10:37 PM
firsthd
Feb 10, 2011 04:16 PM
Sibs
EVO
Sep 23, 2010 10:03 AM
