Cut down the windshield?
Old Feb 15, 2009 | 10:27 AM
vega823's Avatar
vega823
Default Cut down the windshield?
I bought a removable windshield for my FXDC and understand that I should be looking just OVER the top as I am riding. Unfortunately, I have to stretch to see over the top of the windshield. Has anyone cut a windshield down to be able to comfortably see over the top? If so, where would you bring the windshield for this type of modification? Any thoughts on what I should pay for this? I live in Staten Island, NY if there are any of you locals out there with some advice.
Thanks very much in advance for your opinions and advice.
Old Feb 15, 2009 | 11:28 AM
jimmers1817's Avatar
jimmers1817
Everyone has their own preference but since I prefer looking over mine I cut about an inch or so off it. If you have a jig saw it's not that big of a deal. Plenty of sites online that show you how. Other than that probably any glass shop would be able to do it for you.
Old Feb 15, 2009 | 11:47 AM
hdbe's Avatar
hdbe
i look through mine and have no problems.......but cutting it down should be pretty easy...just take you time cutting and then "polish" down to a smooth finish
Old Feb 15, 2009 | 11:50 AM
Fogoms's Avatar
Fogoms
If you're willing to do it yourself, do a forum search and you'll find instructions on how to do it. If you want to send it out, bring it to a glass shop, they can do it for you. I paid $25 to have it done in Northern NJ.
Old Feb 15, 2009 | 12:29 PM
stro1965's Avatar
stro1965
I prefer the clear view of looking over a shield but have learned to live with looking through it for the added wind/debris protection. If I sit up straight, which I rarely do, I can still see over the top. Getting caught in the rain is about the only time I need to do it though.
Old Feb 15, 2009 | 12:38 PM
electaRICK's Avatar
electaRICK
get a big sheet of construction paper,,, trace out the top edge/curve of your shield,
place maskin tape on the shield where you want your new hieght to be,(to prevent scratches from the saw),, trace to line from the construction paper to the tape,,
cut away,, then use a belt sander to smooth edge,,,
So easy a cave man could do it!
Old Feb 15, 2009 | 01:05 PM
max56's Avatar
max56
Veteran: Coast Guard
But, do it on your buddies windshield first, just to make sure.
Old Feb 15, 2009 | 03:50 PM
jberg's Avatar
jberg
I've done two of them pretty much like Rick said.
Cover the shield with tape. Blue painter's tape will do.
Draw the line to match the existing curve or modify it if you like.
Cut real close to the line with a jig saw.
Finish with a series of files, coarse to fine, followed by sandpaper, also coarse to fine. Belt sander can be too much unless you've got a perfect touch.
To really polish edge use 600 wet sandpaper followed by Novus 2 or toothpaste.
Old Feb 15, 2009 | 04:06 PM
jimmers1817
Here's the video that was the biggest help for me. It came out perfect. Getting up the nerve to start is the hard part.
http://www.youtube.com/watch?v=hQj05Db-C3c
Old Feb 15, 2009 | 05:19 PM
EGlideKid's Avatar
EGlideKid
Cover both sides with painter's tape. Trace your line that you want to cut. If you or a friend have a small band saw, that's the best tool for the job. If not, find a woodworking shop or metal house that will do the cutting for you. The backside of a hacksaw blade will take the new edges down nicely. Finish with successive grits of sandpaper, then remove the tape. Voila!
