Engine off best practice
Old Mar 18, 2009 | 02:59 PM
Open Mind's Avatar
Open Mind
Default Engine off best practice
I know some riders who turn the engine off via the ignition switch.
I also know some riders who turn the engine off via the cut-off switch.
Which is a better practice?
Ignition users say that doing this prevents the drainage of battery when parking as sometimes people forget to kill the ignition completely leaving their headlights on.
While
The Engine cut off users say the engine cut off switch is in place to be used and should be used instead of the ignition. As using the ignition is thought to ruin the starting stopping of the motor.
I know nothing of the sort so I come to ask.
What do you all think?
Old Mar 18, 2009 | 03:05 PM
sparky1's Avatar
sparky1
I use both,first cutoff,than ignition.
Old Mar 18, 2009 | 03:12 PM
FastHoss's Avatar
FastHoss
Check your manuel,newer bikes with EFI,turn off by kill switch first.Also a good safety practice,to know where switch is and used to using it.If you are so spaced or don't ride often enough to turn key switch off,oh well.
Old Mar 18, 2009 | 03:16 PM
petemac's Avatar
petemac
I don't think it makes a difference but I always shut off the ignition first and then the kill switch.
Old Mar 18, 2009 | 03:19 PM
Savagehenry's Avatar
Savagehenry
Ah good, a poll!
For me as well: engine cutoff toggle, then ignition switch.
At the risk of thread-hijack accusations, but since it's kinda related; how many people with keyless security actually lock the ignition switch versus relying solely on the security system? (I don't usually use the key)
Old Mar 18, 2009 | 03:21 PM
thomaskray's Avatar
thomaskray
I only use the ignition. Every time I turn off the kill switch, I forget and then the next day I wonder why she won't start. I get worried, and embarassed since it always happens when someone is around. After a moment of panic, I have that "oh ****" moment and swear to never turn off the kill switch ever again.
Old Mar 18, 2009 | 03:25 PM
deadman77's Avatar
deadman77
I used to use the kill switch all the time and then the ignition. I thought I was having a kill switch issue so I stopped using it. Now I just turn off the ignition and leave the kill alone. I have to turn off the ignition and wear it out, but not the kill. I dont see how it matters anyway.
MikeM
Old Mar 18, 2009 | 03:28 PM
papadop88's Avatar
papadop88
I dont think it matters either. But I do use the kill switch first and then the ignition. Just habit I guess.
Old Mar 18, 2009 | 03:29 PM
budnlucy's Avatar
budnlucy
I normally use the kill swtch first and than the ignition. Only lock it when I'm in unfamilar places.
Cajun King's Avatar
Cajun King
I never use the kill switch. I have been around a few people who have and forgot to turn off the ignition after they shut it down with the switch in turn killed the battery. Try finding a new Harley battery in Bum Fu#k Egypt on Sunday morning.
