Flakey jugs help?
Old Mar 23, 2009 | 07:30 PM
dogsong_1013's Avatar
dogsong_1013
Default Flakey jugs help?
My fxdwg is gorgeous except for the black engine paint that has flaked off the jugs and top of block. Does anybody have any ideas on how to repaint ( or at least strip down to a uniform finish) without removing the engine?
Thanks for ANY suggestions!
Schwilly *****
Old Mar 23, 2009 | 08:06 PM
DannyZ71's Avatar
DannyZ71
Have you tried a Sharpie?
Old Mar 23, 2009 | 09:11 PM
bcox's Avatar
bcox
Flakey Jugs !?!?!? With a title like that, I'm a bit surprised that Gumby or electarick haven't chimed in yet You guys are slacking off Seriously the sharpie idea worked for me in the past.
Old Mar 23, 2009 | 10:11 PM
bagman1's Avatar
bagman1
They have a touch up engine paint pen, also a spray can. Thats powder coating on the engine not paint btw. You still under warranty?
Old Mar 23, 2009 | 11:23 PM
Da Gumpmeister's Avatar
Da Gumpmeister
"I refuse to answer on the grounds that tend to incriminate meself"
Harley sells engine paint in aerosol cans. It's a li'l pricey (it says Harley-Davidson, on it) BUT it is good chit. It is a bit 'putsy', but you can mask, use cardboard as a shield, etc. 1000 grit will 'clean up' the edges of the fins, IF you are going that route. The wheels were done with 240, then 1000, and then 2000 to get all the tire iron gouges, scratches, etc out.
NOW, J&P sells "Engine Paint", BUT I have never used theirs, so I cannot speak to it's performance. BUT my gutt tells me, it's prob'ly the same stuff.
This is as close as I can get for a pic of it. I used it on these when I restored them last winter. Guess you can tell, I get '****' about things like this. They're 31 yrs old. You can go as far or as li'l as 'you' like, IT'S your scoot.
Old Mar 27, 2009 | 05:12 PM
dogsong_1013
Thanks for the info the wheels look awesome!
Old Mar 27, 2009 | 05:16 PM
dogsong_1013
Thanks I'm going to try the sharpie! I I don't like the finished product I "test brushed' a little section down to the metal and that looked ok but I'll have to find a really fine brush for the die grinder to do the whole project. I'll post some pics "IF IT EVER STOPS RAINING LONG ENOUGH TO DO IT!"
Old Mar 28, 2009 | 12:27 AM
karz10's Avatar
karz10
ok, I'll say it, tell her to put some lotion on em, they'll be alright
(since you already got your real answer)
Old Mar 28, 2009 | 01:21 AM
Potato_Potato's Avatar
Potato_Potato
I don't think it is powdercoat I think it is high temp engine paint.
Old Mar 28, 2009 | 03:54 AM
xxxflhrci's Avatar
xxxflhrci
Common problem on EVO's. The new Twin Cams don't have much of an issue.
On the cheap, you can mask it off and rattle can the jugs. I would use high heat header paint or barbeque paint.
