I think the rule of thumb is to replace when the tread gets to 2/32. I will run mine bald if I'm know I will just be riding around town. If I have a road trip coming up and it's close, it's time for a new tire.
2 for sure, 3 possible, rears in a year. Front, lasts until the weather check gets too bad, NEVER wears out.
Front is a 'trailer' tire, it jus' 'rolls along'. Back is go AND STOP.
"Also I would replace any tire older that 5 years regardless of tire wear."
Uhh, so you are saying a tire with a '91 manuf. date, is OLD?? Bwahaha
(Front tire on 78 FLH. Just noticed it yesterday when I was working on the front wheel. )
Hopefully you're not spending any time at all on the sidewalls
Only times I have were on the racetrack back when I was still racing and working as a track instructor. Time on the sidewalls is best kept to a minimum!
okay, i didn't mean sidewall, per se, but the area off center from the middle. you know, the part that doesn't touch the ground when you are going straight......
From: Southern California High Desert, here and there....
I knew what you meant. Was just my lame attempt at humor
I just paid 50 bucks to replace my winter air with summer air in the tires and noticed shortly after there was a little thumping. Do you think I Changed too early??
Saw this on a reality show where this guy at a service station was charging people to change out their winter air for summer air and he was actualy making money off this. could not stop laughin.
Anyway I have the same thing going on and when in doubt it is most likey time to replace. Like mentioned earlier there is an arrow on the sidewall indicating the location of the tread bar. When this appears and is close to the surface it is time. Its a little pricy but don't skimp on tires...they are whats between you and the road!
Last summer I had an appointment set up at the dealer for a new rear tire. The weather was nice and I thought I could get a small 200 mile ride in before I brought it in. I had the rear go down at 75 MPH. I NEVER want to go through that again. 7500 miles.
I'm not doubting everyone and I guess I may be the one "out of step" here. But in my case while the rear tire pushes it along, the front tire takes almost all the breaking. The rear pretty much just gets the engine braking. The only times I even touch the rear brake is under seldom *hard* braking (when I use both), slow tight turns, or when on gravel or grass. The front tire initiates all your steering and maintains the lean, which is why they usually wear out just off center.
I'd think especially on the E Glides and Road Glides, with their fairings, the front tires would take a lot of wear? I'll find out on my E Glide, I hope I get to ride it enough to wear the tires out this year!
On my FXDX I tried replacing just the rear, before a 5K trip. The rear had 6,000 miles and the rear was getting close to worn out but I thought the front *may* last another 5,000 so I left it on. 3,000 later in Colorado the front was almost slick on the sides. So I lost much of a day riding to a dealer and waiting for them to install a new front. Then they charged me more for that front than I would have paid for both front and rear, which I would have mounted myself at home.
