That Famous Wobble
Old Apr 19, 2009 | 12:33 PM
DeadStick's Avatar
DeadStick
Never been in a dangerous situation, but my '06 RK definitely had that loosey-goosey feeling in the rear. The TWR Missing Link stabilizer did the trick for me, and dozens of other forum members here. Makes a huge difference – my bike now has a feeling of longitudinal stiffness, esp. at speed, and once on a line "sticks" to that line much better. Read the install instructions and reviews here:
https://www.hdforums.com/forum/touri...nd-review.html
From what I've read, all the stabilizers on the market work in basically the same way. I chose the TWR because it won't interfere with a center stand or lift.
Old Apr 19, 2009 | 12:59 PM
will2002's Avatar
will2002
Let me tell ya, If you EVER experience the "wobble", You will dam sure know it. You will not have to wonder about it!!! A Throttle-Up Touring Stablizer fixed the problems for me.
Old Apr 19, 2009 | 01:13 PM
rickxx's Avatar
rickxx
put my throttle up stabilizer on the sg yesterday. took it for a ride and i could definitely tell a difference in handling. tracks great.
Old Apr 19, 2009 | 02:55 PM
cowboy1's Avatar
cowboy1
Thanks. The link and directions look simple and I will look into it. I see you are in San Mateo. Did you go to the Ness show yesterday? It was pretty good. Mama and I went up from here and had a good ride then shot over to Amici's for some pie.
Old Apr 19, 2009 | 03:51 PM
6 gun's Avatar
6 gun
look up stablizers on this forum I got the one from what used to be throttle up industries
and i love it
Old Apr 19, 2009 | 04:28 PM
3dynaP's Avatar
3dynaP
No wobbles for me. '08 Ultra.
Old Apr 19, 2009 | 04:53 PM
SportsterBob's Avatar
SportsterBob
I know all about that wobble....it occured at 35-mph and around 100-mph. It was a spoked front wheel and I did the investment of a basic wheel balancing stand and a few wheel weights.
I put the front wheel in the balancer and did the "old-school" static balance....
1.) Allow the wheel assy to find it's heavy spot. It will move back and forth while gravity does it's work. The heaveist end will be closest to the ground. Place a weight at the opposite end of that heaviest point.
2.) Move the wheel assy to any spot and let go....
3.) If the wheel does not rotate, you are finished
4.) If the wheel still rotates towards the same heavy spot, add another weight next to the one you just added an go back to step 2
Old Apr 19, 2009 | 05:38 PM
chuck2000RK's Avatar
chuck2000RK
i have experienced the bagger wobble. it happens in corners at speed. when i put the right amount of pressure in the forks and shocks and swapped out tires for metzelers and all is good now.
Old Apr 19, 2009 | 06:59 PM
stro1965's Avatar
stro1965
If anyone is interested, I was pointed to a link on eBay for the Progressive stabilizer (very similar to the missing link one I think) for $140.00 plus $20.00 shipping. Search on eBay and you'll find it. Lowest price I could find for any of them.
Old Apr 20, 2009 | 03:09 PM
Ultra110's Avatar
Ultra110
Originally Posted by lh4x4
The wobble is not a speed wobble in the front end. It is swing arm flex. To experience it you must be riding two up with tourpack, saddle bags and other bags overloaded. Then when you go into a sweeper hot, the rear will do a little wobble. That's what was corrected with the 09 touring models.
Not true! I have experienced the wobble in question with empty bags and pack. I weigh 195. I have felt this on a couple of different sections of road. At speeds of 45 MPH and well lets say in excess of the legal limit. I will say it seems to happen on a sweeping turn with a little wave or hump in it. There is a section of the interstate here in NH that is a sweeping left hand turn and a slight uphil grade that has a riple in it. I can get the wobble 9 times out of 10 going around this. More pronounced the higher the speed. First time the ol Sphincter factor was pretty high.
