Valve Adjustment?
Old Apr 20, 2009 | 10:24 PM
gascap13's Avatar
gascap13
Default Valve Adjustment or Air Cleaner?
Adjusted valves today, runs strong but gets hot. I adjusted them to 3.5 turns with 24tpi threads on adjustable push rods. Is this too tight? Would tight valves overheat motor?
Old Apr 20, 2009 | 10:56 PM
gascap13's Avatar
gascap13
... and besides the valve adjustment, I did not reinstall the air cleaner cover for the test ride and it may have been breathing a little better. Would the lack of air cleaner cover make MORE heat due to being lean?
Old Apr 21, 2009 | 12:33 AM
Other Sheep's Avatar
Other Sheep
If the air filter was in place without the cover it wouldn't make that much difference. No clue on the valve adjustment, sorry.
Old Apr 21, 2009 | 06:58 AM
1flhtk4me's Avatar
1flhtk4me
"Tight" valves could make them stay opened.
Did you adjust the pushrods because of noise or heat?
I think heat would be related to tuning.
simonantz
Mar 28, 2016 11:10 PM
creatv1
Jun 11, 2010 11:46 AM
gascap13
Apr 21, 2009 06:52 PM
sharkeydude
Jul 28, 2008 04:43 PM
docsg
Aug 25, 2007 12:38 AM
