Normal down shifting does not hurt and is the proper way to slow along with light brake but if you are going to the point sliding the rear tire or almost sliding it the reverse pressure on the rings can pop them I know this for a fact, brother inlaw like to listen to tire slide and eng. rev. till he popped rings on a cyl. and inbedded them in top of piston.
I can see what he's saying and that's kinda how I started out but, you must be one super jet-eye focused dude cause I could never remember excaty what gear I was in or loose track while down shifting... Then let out the clucth for that "situation" and F*** around and still be in the wrong gear.
Down shifting as I'm slowing down alows me to KNOW I'm in the right gear by the sound and feel of the bike. You don't get that with the clutch pulled in coasting.
Thanks everyone,
Jason
+2
I have trouble remembering what gear I am flying through when not using the engine. And when I need to let it out to accelrate I am always in the wrong gear. I have always downshifted using the engine but not too high of an RPM. When approaching a light and it turns green I would be lost because I am just not so bright. Just want to think about ridding. I think the Manual states this as well?
I go slowly down gears anyways like towards a red light just in case it turns green so I dont have to quickly shift up to whatever gear I should be in. At stop signs though always used my brakes...i HAVE engine braked before though...
LOL.. So I guess all of the basic skills and MSF instructors should re-think their lessons on stopping a motorcycle?
Actually I don't coast, I use the brakes, and I'll be danged if it don't stop me every time.
LOL.....and do you even get out of 2nd gear in MSF???.....I'm confused.
Also those that say why down shift and just use the brakes! So basically what you're saying is that when you are going down a street at 45mph and you see a red light up a head you pull your clutch and use your brakes?? Because at some point as you slow down you are going to down shift, whcih uses your engine to slow down no matter how you look at it.
In any emergency stop or for that matter in general I agree, it is best to use both gearing, compression braking and mechanical braking.
I have had this discussion with two HD master mechanics. Both tell me to downshift only to 3 rd gear and not to cause any high decompression type shifts especially into 2 and primarily 1st gear. They say it's a good way to sissor or possibly shift the flywheels out of balance as well as abnormal wear on rest of the drivetrain. Normal downshifts are fine when riding but not so great when comming to a stop sign. I'll take their recommendation on good faith.
