engine braking good or bad
Thanks guys, I got a wealth of information outta that... I actually agree with you both. You guys have light years of experience on me but, it's nice to pick your brains.
I took MSF and DO use breaks only in an all out emergency, and actually if I know I'm in 5th and no one is around I will hold in the clutch as I'm coasting slowly clicking down thru the gears only using the break to stop. But, most of my riding time so far is in and around downtown Dallas so routine is to apply light break and E-break down thru the gears so I can skeet out of there if need be or grab the clutch and breaks and stop if need be.
Thanks Again,
Jason
In a racing aspect-you never use engine braking-That is the one time you can over rev your engine and cause major damage. The rev limiter only works in acceleration.
you never go from a different gear, without going through all the gears between. i.e. from 6th to 2nd, you'd go from 6, then 5, 4, 3, 2. never just straight from 6 to 2. the PROPER way to do that is by downshifting while slowing down.
i've engine braked on all my vehicles for well over 500,000 combined miles, and have never had any problems because of it. not only does it save your brakes, it allows you to slow down faster while braking, and get out of a corner faster.
But you ride just like you want to....it's your bike
But don't ya just love it when the newbees pull in the clutch at 50mph and coast allllllll the way to a stop then struggle to find any gear at all?
I saw in the H-D manual that the MoCo set the weight standards for the Electra Glides, they figured 150 lbs for the rider and 100 lbs for the passenger for a total of 250 max. recommended people weight. They gotta be kidding!!! At 6'5", I'd hate to weigh-in at 150...
I changed my riding habits (reduced/quit downshifting) and my rear tire mileage has increased to about 7500 miles before I have to get a new tire. I'm wondering if the new 09 models will do better on mileage due to the larger tire?
