reving when shifting
Old May 11, 2009 | 10:11 AM
hotrod351's Avatar
hotrod351
Default reving when shifting
just wondered why so many guys rev there motors up when they down shift. bad transmissions. is it suppose to make it easier to down shift.
Old May 11, 2009 | 10:19 AM
capnhook's Avatar
capnhook
Because it sounds cool.
But actually it does make a smoother ride, and is easier on your clutch.
Old May 11, 2009 | 10:23 AM
hounddog1257's Avatar
hounddog1257
Its called rev matching, so your rpms stay the same if im not mistaken. see below same for a bike and car
When changing up or down, avoiding any kind of shock loads through the transmission is essential, especially in a powerful car. When changing down, releasing the clutch rapidly can result in rapid forward weight transfers and in extreme cases, the driven wheels can lock. Use rev matching where possible to smooth out down changes, and release the clutch with mechanical sympathy in mind. When changing up, remember that a missed gear due to a rushed gear change is much worse than taking a little more care with the shifts. Never change gear mid-corner - when approaching a bend ensure you prepare by selecting a gear which will allow you to accelerate out
Old May 11, 2009 | 11:15 AM
bigc00p's Avatar
bigc00p
x2 - definitely makes the downshift smoother, and it sounds cool..
Old May 11, 2009 | 11:27 AM
HOTLAP's Avatar
HOTLAP
Yup I give it a burp on every downshift.
As said above, smoother, easier on the gear box and clutch plus sounds good too.
Old May 11, 2009 | 11:44 AM
Slowpoke84's Avatar
Slowpoke84
Because it's cool, that's why. Proper rev matching would be smoothly throttling up to the proper RPMs to match where they'd be after downshifting. However, like in the article hounddog1257 linked, "any increase in revs is better than none." So, just rev it quick, cuz it sounds cool , and you're good to go.
Other Sheep's Avatar
Other Sheep
When Harley first made the balanced twin cam for the softails they tried to use the old evo tranny. It was then that they discovered that the vibrations from the evo were helping the tranny to shift and so they designed a new tranny for the balanced motors. If you have an evo you'll find that it's much easier to find neutral at a stop if you rev the motor a little as you're shifting. Old habits die hard.
Old May 11, 2009 | 11:53 AM
cadman311's Avatar
cadman311
No we don't use your brakes unless we need to stop.
Old May 11, 2009 | 11:58 AM
GregH's Avatar
GregH
Never seen the point in "rev matching". I've found that by properly adjusting my speed to the traffic conditions, there is no need to rev the bike. I can down shift without any sudden shock load that would cause undue stress on my bike. My bike is quite loud and sounds cool enough when I accelerate through the gears that I don't feel the need for additional reving that will bring more unwanted attention to myself.
In short, I believe that it totally unnecessary unless one is doing some type of high performance driving, like on a track or something.
Old May 11, 2009 | 12:27 PM
dumernarock's Avatar
dumernarock
I agree, it is totally unnecessary.
However riding a motorcycle for pleasure is also totally unnecessary.
