exhaust "sniffed"?????
Thanks,
Larry
They stick a sampling tube, into the exhaust pipe. It draws in the exhaust, and analyzes it for CO, CO2, etc. Using that data, they can then determine, what adjustments to make to your EFI or carb, etc.
In reality, TMK, it is the only way to really dial it in.
Those of you, living in 'smog control' states, should be familiar with this, IF not, you will be 'chortly'. Think air quality, Climate Change and BIG BROTHER!!!!
Jack Butts!!!
Course, you could jus' git 4 or 5 of your buds over, fire it up, and then everyone stand behind it, and SNIFF. YEP, she's burnin' rich, I can smell it.
BUT clear your 'sniff' palates with a case of Michelob (or your favorite brand), FIRST!!!! You will attain MUCH BETTA results. Not sure the scoot will run any better, BUT, GOOD results.
Unless of course you're using the "seat of your pants" method, which doesn't use a sniffer other than maybe your nose.
