What gear do you use?
Old May 23, 2009 | 01:45 AM
rockDAWG's Avatar
rockDAWG
Default What gear do you use?
I bought the Ride Like a Pro V DVD. It really helps me. Now I can do a Figure 8 tightly without any problems. Unfortunately, mine is not as elegant as Motorman, I need more practice.
One thing he does not mention in the dvd is the gear he uses. I have been using 1st gear, but I think 2nd may be better. Any one have any input?
Old May 23, 2009 | 02:12 AM
murd's Avatar
murd
First or second, depending on your speed (or lack of it) still relies on your friction zone.
Start off in first gear, work the FZ, second, do the same. You'll find it no matter what. Keep on practicing til it's second nature.
-ride safe...
Old May 28, 2009 | 05:47 PM
rockDAWG's Avatar
rockDAWG
I have been practicing every free time I have. We have a huge cud de sac in a very very quite street, so every time I get bored. I ride my bike like a little kid. It is actually very fun.
I found 2nd gear works better a lot smoother. The first gear is bit too torqky for me but it force to use FZ more.
Old May 28, 2009 | 06:05 PM
bobernet's Avatar
bobernet
Generally always first gear for me at parking lot speeds. If 1st is too herky jerky for you, you might try gently riding the rear brake while keeping the engine rpm consistent.
Old May 28, 2009 | 07:16 PM
edilgdaor's Avatar
edilgdaor
Yep, I've found I drag the rear brake without even thinking about it.
Old May 28, 2009 | 07:26 PM
electricstart's Avatar
electricstart
I have been doing motormans practice also ,Do you think that slow speed hurts the machine? Good stuff ,I like it a lot but don't want to ruin clutch.
Old May 29, 2009 | 08:34 AM
BugBYter's Avatar
BugBYter
A Wet clutch will take a lot more abuse than a dry one, but there still must be some wear. I'll use the friction zone for a few minutes and then make sure I competely depress the clutch lever for a few seconds to allow cooler oil between the plates. Then after 20 minutes or so, depending on outside temperature, I'll ride the bike normally for a few miles to cool off the engine, brake and clutch. I'm more concerned with overheating the rear brake than hurting the wet clutch.
Old May 29, 2009 | 08:37 AM
BigGdawg's Avatar
BigGdawg
1st gear is for low speed maneuvers. Rear brake and friction zone are the other factors to keep in mind.
Old May 29, 2009 | 11:05 AM
rockDAWG's Avatar
rockDAWG
I agree with BugBYter, wet clutch will take a lot and lot of beating before it goes. With a proper level of motor oil, 3.5 qt, I doubt the clutch plate will burn. I also think that the low speed in the figure 8 practice will not hurt the rear brake either because the speed is so low. I often practice an hour at a time, don't smell any smoke and not sign of over heating. But I do go for a short ride around the neighhood before quit each time.
Old May 29, 2009 | 11:16 AM
carpetride's Avatar
carpetride
How many real world places are you gonna do figure eights?
Low speed practice is good but you ARE wearing on the clutch so I wouldn't do it a lot. IMO
