It doesn't really matter why he wants a chain, though does it? All that matters is he wanted it and asked for a quote to get it done. The answer should have been the quote he asked for or a polite "Sorry, we don't do that kind of work." It should not have been a debate.
I'll bet the parts guy has been conditioned to react that way because of the dozens of people who have bought bikes, but really don't know anything about them. It wouldn't surprise me if he had sold something like that before only to have some guy come back and complain when he had to replace the chain or when it slung grease on his chaps.
If you want a chain - go for it. The belt AND REAR PULLEY had to be replaced on my Ultra at only 45,000 miles. Tension was always correct, but I just never thought to check the teeth on the belt by trying to bend them or flex'em. Went in to get a new rear tire put on and the wrench came out and told about my new problem. I never really gave the belt teeth a second thought because I had been told they last forever....just checked the tension regularly.
About every 5th tooth was missing and all the rest worn torn and just being held on by near nothing. The grooves in the pulley were rough and gapped really bad. The kicker is - I had just got back from a 2,300 mile trip to West Virgina. The bike is a 2007 model and has never been hot-rodded..too much. What happened to my belt? The dealership just said that they usually go out at about 60-70 thousand miles.
That belt wasn't all that impressive - maybe a chain would be another idea....
I was a Harley Tech in the late 80's and early 90's. I always preached to my customers to check their pulleys. That's the main reason for premature belt failure. The belts are stronger than the teeth on the pulley's and they often wear the teeth down to an almost razor sharp edge and pretty soon...there goes the belt. I don't know about now but then you could go through two pulley's before you needed to change a belt.
Chains and don't last as long on sport bikes anymore because they are being yanked by 150-170 horsepower engines. On a Harley I would think that a chain would last much longer.
Seem to remember seeing a chain with chrome sideplates and hardened rollers on a custom last year and it also had o-rings . Looked great on that bike. Might have been polished stainless, but if so, it was one heck of a polishing job.
As far as telling you some $hit about needing to change it often, I personally think they are trained to tell the general population BS. My dad is pretty good buddies with the service guy at his local HD dealer. We were swapping bars and risers and started asking questions. He instantly told us, "hey, lets go outside and look at your bike". Once we got outside he told us, "Now that we are outside I can be honest, but in there I have to give you the trained sales line." He told us specifically that he has to tell you that if you change this or that, then you are going to specifically have to buy these and those. My point being that like doing bars and risers, they HAVE to tell you that changing cables and wires are mandatory, even though everyone with a brain can see that you can get away with quite a bit re-routing, cutting and soldering before you have to start swapping parts... As far as chain goes, I would think that chain is getting better and stronger, not $hittier and weaker... Just my $.02
All the years I ran chain it never mattered how long they lasted because they cost so little.When they needed changing they got changed,I ran industial chain and it was cheap.After seeing what the belts today can take for punishment I am forever converted.But,to convert to chain is not all that expensive especially if you do it yourself.When putting my last bike together I looked into it.Chain costs more than the sprockets.Good Luck
