Bonehead move
Old May 18, 2006 | 02:38 PM
cosmo glider's Avatar
cosmo glider
Default RE: Bonehead move
That's why I won't wear lace up boots.
Old May 18, 2006 | 02:40 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Aw that hurts.....but it's why I just installed engine guards. Lots of damage happens in the garage & driveway. You might try getting a piece of dry ice and rubbing it on the dent. I have seen some guys pull small dings out of auto sheet metal with dry ice. I think it's what the dent shops use. They rub the dry ice around the outside edge of the dent itself and the metal contracts. Then hold it on the dent for a minute or two and see if it shrinks out. No guarantee but I have seen it work before.
Old May 18, 2006 | 06:41 PM
fxstcguy98's Avatar
fxstcguy98
what KB said, here is a link to it in the DIY section. You can also use a can of compressed air turned upside down or butane instead of dry ice.
https://www.hdforums.com/m_68440/tm.htm
Old May 18, 2006 | 07:21 PM
bragz's Avatar
bragz
Thx for the info! I'll give it a whirl.
Old May 18, 2006 | 07:57 PM
sprintrps's Avatar
sprintrps
I think it is ruined and you should sell it to me real cheap!!!
Old May 18, 2006 | 08:07 PM
alazlo's Avatar
alazlo
I had the Dent wizard push a ding out on an FLH tank about the same size as you describe and you couldn't find the spot when he was done but on an FLH tank there is a large opening in the top of the tank for him to get inside with his prybars & work it. There is a chance the DentWizard Dentless repair might be able to do it.
Old May 19, 2006 | 12:43 AM
Pauljr's Avatar
Pauljr
Good thing it was you that did it. What would you have done if that little
bastard Johnny where to have knocked it over ?
Old May 19, 2006 | 02:00 AM
kjriv's Avatar
kjriv
damnn---sorry to hear that.
That dry ice trick is awesome fellas - gotta try that on the truck!!
Hope you blew the crap up outta that skateboard tho!!
frontporchblues
May 8, 2014 07:10 PM
Rnt77
Aug 12, 2013 05:20 PM
macgrg
Apr 18, 2010 11:27 PM
mr_m
Nov 16, 2009 07:21 PM
A7X
Sep 16, 2009 05:05 AM
