Handling problem
Old Jun 21, 2009 | 03:28 PM
GT_RoadGlide's Avatar
GT_RoadGlide
Default Handling problem
Have you ever driven on rain groves or on a bridge deck that is open metal grate? If you have then you know how the bike wants to “dance” around. My problem is that above 55 mph my 07 RG wants to do the same thing. It doesn’t do it all the time, just most of the time. This is a straight line driving problem. If I’m in dirty air behind a truck it gets worse.
It started after I had new tires and wheels installed. I run the tires at 40 psi.
Any ideas what the problem might be? I sure could use some suggestions.
Thanks for the suggestions. The RG comes with a cast spoke wheel and I had the below wheels installed. The new tires were the same Dunlops that came new with the bike.
Here's what fixed the problem. I was watching a motorcycle program yesterday and they were talking about suspension tuning and tires. That got me to thinking about air shock pressure. I dropped the front and back tire pressure to 37 psi and increased the air shocks to 12 psi. That took care of the problem! Thanks again.
And for beer, I'll take a Newcastle brown.
Old Jun 21, 2009 | 05:16 PM
C R's Avatar
C R
It probably would'nt hurt to make sure the're still balanced right(spokes,cast wheels ?) it's not unheard of for a stick on weight to come off a cast wheel.I would at least take it to where you got them and tell them the problems you're having
and have them double check every thing they did .
Old Jun 21, 2009 | 05:46 PM
Splatter's Avatar
Splatter
I'd blame your tires. If they have tread lines that run parallel to the walls of the tire, they're going to have a groove problem. Most modern motorcycle tires have tread lines that diagonal to the walls for that reason. If your bike is getting tossed around in the turbulance behind trucks, that's a different issue. I have a Super Brace on mine (Dyna Super Glide) that cleared up any tendencies in that direction -- though it was a pretty stable bike to begin with.
Old Jun 21, 2009 | 06:01 PM
badwhine's Avatar
badwhine
spokes? tire pressure? neck bearing/fall away? aftermarket trinkets? tires? just a few suggestions.
Old Jun 21, 2009 | 10:08 PM
RexBuck's Avatar
RexBuck
If you have D402s or Michelin Commanders, you will think your bike has turned into a professional dancer across grated bridges, rain grooves and grooved pavement. Try E3s or Metzlers and your problem will likely be resolved.
Old Jun 21, 2009 | 10:10 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Tires that do not have grooves that go the same way as the rain grooves on the pavement will make all the difference in the world. I found a great difference from running Metzler's or Avon's.
Old Jun 21, 2009 | 10:37 PM
asm481's Avatar
asm481
I have found making a slight change in attitude helps on things such as metal bridges. What I mean is to drift from one side of the lane to the other. Nothing radical mind you. Just a bit of input to control the bike.
Old Jun 21, 2009 | 10:53 PM
wescoot2's Avatar
wescoot2
Id take it back to whoever you bought the rims and tires from and let them figure out what's going on. Could be many different areas, but whoever did the work should be responsible for the problem.
Respects,
Ed
Old Jun 21, 2009 | 11:15 PM
bagman1's Avatar
bagman1
I use to have that issue with dunlops, but no more with metzlers
Old Jun 21, 2009 | 11:36 PM
NICK_AK's Avatar
NICK_AK
6th Gear
I'd bet ya a beer it's loose spokes back there.
