head work?
Old Jun 29, 2009 | 01:32 PM
dr's Avatar
dr
Default head work?
How much difference did have your heads re-worked make? ie. ported and polished
Old Jun 29, 2009 | 03:13 PM
Centerline's Avatar
Centerline
There are so many variables, but I will hazard a wild guess that something less than 1/2 the upper range RWHP my bike gained (it gained 42 hp over stock) was due to ported heads and revalved heads.
Old Jun 29, 2009 | 03:33 PM
cHarley's Avatar
cHarley
From headwork alone? Man, I'd like to see that before and after dyno sheet. Wonder where the torque went?
Old Jun 29, 2009 | 04:05 PM
Slowpoke84's Avatar
Slowpoke84
Check out his signature. More than just head work.
Then, in my signature, you can see what I gained from the 95" kit with headwork and cams.
Old Jun 29, 2009 | 04:24 PM
dyna2319's Avatar
dyna2319
Heads are just part of the system that makes power. You have to remember that you can build them for high HP, which is not really usable on the street. Or you make some torque which is very usable on the street. You are looking for high flow rates at moderate RPMs for street use and the outrageous velocity for the track use. This has to work in unison with the cam, compression, exhaust etc. that you have selected. You may have all the best parts but they don't work together as a team.
Old Jun 30, 2009 | 05:46 AM
dr's Avatar
dr
Reason I'm asking is I have a 07SG with a 103 stage 2. Was thinking maybe reworking the heads or going with a different set would bump up the uper rpm range some. Seems to fall off some after @4500rpm
Old Jun 30, 2009 | 04:59 PM
red devil's Avatar
red devil
Heads are were its at! Since you already have a 103", adding heads or reworking your stock ones will get you at least 10 more hp.
Old Jun 30, 2009 | 09:20 PM
jag1886's Avatar
jag1886
I did head work on my 2000 1200 Sportster it has stock cams and 10.75 compression and makes right at 85HP at the rear wheel, that's close to a 100HP at the crank just like a Buell but with smaller valves and cams and it cranks on from the crack of the throttle to 6000 RPM's.
Head work can make a phenomenal differance!!
Big_O
Engine Mechanical Topics
45
Jan 21, 2023 05:41 PM
2rays
Mar 30, 2013 03:25 PM
bagger76
Dec 7, 2010 07:14 AM
HD Renegade
Apr 16, 2009 04:01 PM
fiddledicksr
Exhaust System Topics
Apr 20, 2007 01:47 PM
