ABS on harleys
I'll never own another bike without it.
Normal riding conditions, Wet or dry, the ABS doesn't kick in. I have NEVER had it kick in on bumps, so if yours is doing that, take it to the dealer for proper calibration.
ABS is designed for any vehicle, to do one thing. Allow you to maintain control in a panic stop situation. It does that extremely well in every vehicle I have ever driven.
Those that claim they can stop faster without ABS, have not done so in a Panic situation. If I am controlling the situation, (braking on a line) I am not panicing. This is not an emergency stop, and you MIGHT be able to stop faster without the ABS, but try doing the same when some moron in a car pulls out 30 ft in front of you, while you are doing 45 or better mph. I can damned near gaurentee that you are gonna hit that Moron, or dump your bike trying to avoid him.
I have heard from so many that they "Layed her down" ..BULLCHIT. you never Layed her down, You CRASHED! A motorcycle is designed to be ridden UPRIGHT with both wheels making contact with the road surface. When you are not in that upright position, you CRASHED! Period.
on the road in 50,000 miles of ridein ABS will out perform almost everyone.
Its like anything else you're gonna like it or not, you like ford i like chevy...blah blah blah
everyone just STFU and ride!!!!
http://www.motorcyclecruiser.com/str...ths/index.html
If anyone is considering whether or not to get ABS, get them. End of statement.
The following link is old, but still valuable. As you read it, bear in mind that ABS systems are even better now. Also bear in mind that in the few instances where non-ABS bikes stopped faster, it was in the dry by an expert in a CONTROLLED situation.
http://www.ibmwr.org/prodreview/abstests.html
For anyone that doesn't want to read it, here is a chart from it:
non-ABS 158 ft
w/ ABS 163 ft
Full ABS Control 166 ft
non-ABS 181 ft
w/ ABS 172 ft
Full ABS Control 167 ft
non-ABS 160 ft
w/ ABS 165 ft
Full ABS Control 162 ft
non-ABS 186 ft
w/ ABS 167 ft
non-ABS 199 ft
w/ ABS 171 ft
Full ABS Control 169 ft
non-ABS 180ft
w/ ABS 168 ft
I won't reprint the wet chart because the non-ABS bikes aren't even close under any conditions.
