Primary Chain adjustment Pad
Old Jul 7, 2009 | 05:44 PM
wescoot2's Avatar
wescoot2
Default Primary Chain adjustment Pad
Have you had to replace your Adjustment pad on your primary? If so, at what mileage did you change it out ?
Thanks,
Ed
Old Jul 7, 2009 | 06:26 PM
Uncle Scrooge's Avatar
Uncle Scrooge
I'm curious about this too. A quick search doesn't turn up anything, and I can't remember any complaints about worn out primary pads. Wonder why these seem to wear so much better than the TC88 cam tensioner pads.
Old Jul 7, 2009 | 06:38 PM
RoadKingRon1's Avatar
RoadKingRon1
Hey Wes, yep. At about 27K miles. Had a vibration nobody could find for a few thousand miles. Was servicing the bike, as the primary was draining I noticed it was slow to do so. We pulled the cover and there by the drain hole was a piece of nylon pad.
Put a new pad on, adjusted the chain, buttoned her up and the vibration was gone.
Piece of cake.
edit: Mine was cracked/broken not worn. Small pieces of nylon actually embedded into the links of the chain.
Old Jul 7, 2009 | 06:42 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Different, better material and possibly slower chain speed. The only time I've seen these on threads is one breaks, again rarely
Old Jul 7, 2009 | 08:17 PM
wescoot2's Avatar
wescoot2
Here's the deal.......a couple of weeks ago on a 350 miles ride....I suddenly start hearing a clanking noise coming from the primary. Couple of days later, I adjust the primary chain, drain and add new fluid, and all is good. A few weeks later, that clanking is starting again. When I checked the pad when I adjusted it last, it's hard to see how much of the pad has been worn down. I figured with 73K miles, I'll tear it down, and put in a new pad....30.00 bucks for parts, and a quart of oil, with some up close and personal time with the scoot sounds like a fine way to waste a rainy day.
After I get the pad off and can get a good look at the worn pattern, I'll report back.
Thanks for your input......
Ed
Old Jul 7, 2009 | 08:25 PM
freebyrd's Avatar
freebyrd
ok whats a primary pad? are you talking about the frisbee gasket? mine has a ring gasket and i don't think i've ever changed it
freebyrd
Old Jul 7, 2009 | 08:36 PM
wescoot2's Avatar
wescoot2
I have an 01 Wide Glide.....in the Primary, the Chain's tension is adjusted by raising or lowering a plastic pad (shoe) which the chain runs against. Very much like the old Cam chain tensioners.
Ed
Old Jul 7, 2009 | 08:40 PM
Juve996's Avatar
Juve996
freebyrd
The frisbee gasket fits around the derby cover. What you see under the derby cover is the clutch assy. The primary chain is inside that case, it connects the crankshaft to the clutch assy. A primary pad is the tensioning system that takes the slack off the primary chain. This pad is made of a composite material I believe that is spring loaded to keep the chain snug. This tensioner mechanism on newer models are made a bit better with better lubrication which extends the life of the pad.. I believe this is accurate, I may be wrong..
Old Jul 7, 2009 | 09:39 PM
Uncle Scrooge
In order to see the primary pad without removing the whole primary cover, you need a bike with a primary chain inspection port. You will find these only on Big Twin 06s or earlier (05s or earlier I think on Dynas). When HD went to the automatic primary chain tensioner, it removed the need for easy access to check chain tension regularly.
Old Jul 7, 2009 | 10:11 PM
MidnitEvil's Avatar
MidnitEvil
I didn't have a problem with my primary chain tension, but threw an automatic chain tensioner on at my 20,000 mile service. I figure that's one less thing I need to adjust or check on future services.
