Riding on light road gravel
Old Jul 13, 2009 | 03:02 PM
BucksBike's Avatar
BucksBike
Default Riding on light road gravel
Having not ridden for 30+ years I don't remember whether the small amount of gravel that sometimes accumulates in the center of a lane is something that needs to be avoided in turns. I probably never gave a second thought 30 years ago. I came across some yesterday riding on some less traveled roads but coud tell that it might be something not easy to see all the time.
Old Jul 13, 2009 | 03:09 PM
frog13's Avatar
frog13
Personally I hate gravel, but it is a necessary evil if you want to ride. The two places I find it to be especially dangerous are in turns and at stop signs. Turns are self explanatory, when the wheel slides out, things get exciting. At stops, I have seen many a rider apply a little too much front brake, getting the front tire to skid and losing control. If you have room and the gravel gets you, believe it or not, many times acceleration, not braking, is the better answer even if it does go against all instincts.
Old Jul 13, 2009 | 03:16 PM
yk.hd's Avatar
yk.hd
Yep... best to steer clear of the accumulated stuff. Frog's got a great point there; sometimes it goes against your every instinct - but when you're in the loose stuff and you start to slide; twist on some more throttle to spin your way out... Power through it they say.
Old Jul 13, 2009 | 03:27 PM
EG Ultra Classic's Avatar
EG Ultra Classic
I always try and ride in the left of center wheel track on pavement. Never ride in the center of the lane as that is where the oil and other road debrie tends to collect. By riding Left of center, you have a lot more room to maneuver and better visibility to oncoming traffic.
As far as gravel roads, I run then also in the wheel track, usually L. center wheel track which ends up being the center of the road. When I get in the lose marbles, such as to give oncoming traffic room, the main thing is to slow down and let the back wheel wander around a bit while holding the bars steady to slightly right. Once in the right wheel track, steady up straight in the track and speed up back to 40 until traffic is past and you can then slow down and get back in the center of the road lane. Don't fight the rear wheel wandering by making steering corrections-- you will go down. Don't try any sudden braking or turning or leaning. You will go down. Do things much slower and deliberately on gravel roads than on pavement. Usually 40-45 mph is about right on gravel. It sucks, but you will be alright. Just take it easy.
Old Jul 13, 2009 | 03:33 PM
CinBob's Avatar
CinBob
I had my first gravel road experience...knowing I was going onto gravel, I researched 'tips' before I left. Well....when I got up to where I was going - not only was it gravel - it was FRESH THICK gravel...ALL OVER the freakin' road!!! The only quote I kept thinking, was hands firm on the grip, and let the bike find it's own path. Not sure what speed to go, I kept it about 35 mph, which may have been a bit slow, but eh, I made it - about 2 miles in and 2 miles out...in the midst of which was a stop at the bottom of a hill. eeeeeeeeeesh!! Say a prayer and trust the gnarly!
Old Jul 13, 2009 | 04:23 PM
will2002's Avatar
will2002
It's just like riding on little ball bearings! If ya like that, youre gonna be just fine.
Old Jul 13, 2009 | 04:47 PM
2K1FLHPI's Avatar
2K1FLHPI
Gravel is bad news. Ride straight and evenly. When turning or stopping on the stuff, it is simple ice.
hogowner69
11
Jul 2, 2015 06:31 AM
kzoo
Jul 7, 2014 03:18 PM
Ben221
Jun 24, 2013 10:40 AM
SalsaNChips
Apr 1, 2010 08:32 PM
rbabos
Oct 18, 2008 05:29 PM
