Can your harley be bump started??
Old Jul 16, 2009 | 12:30 PM
CWDoc115's Avatar
CWDoc115
There was a posting a while back where someone with EFI tried this, and it would not start.
Old Jul 16, 2009 | 12:31 PM
will2002's Avatar
will2002
But Gump, ......Ya look soooo dam kool kikkin it over ! Just like ole Easy Rider, ya know?
Old Jul 16, 2009 | 12:41 PM
xFreebirdx's Avatar
xFreebirdx
I've done it when needed.
Old Jul 16, 2009 | 12:42 PM
DuraGlide's Avatar
DuraGlide
You would need at least 10 volts for the ECM to function and the fuel pump to build up pressure on the newer bikes. So if the battery is graveyard dead it ain't gonna start. Won't have enough crankshft rpm for the alternator to help either unless you push very fast a very long way. Have helped bump start 2 bikes this year. One was a fuel injected dyna with starter circuit issues and one was a sporty that the battery was weak but not totally dead.
Old Jul 16, 2009 | 12:43 PM
bfrmbama's Avatar
bfrmbama
I've always heard you couldn't push start an EFI if the battery is dead. Someone posted that they were able to. Now I'm just curious, can it be done?
I've got a carbed '03...
Old Jul 16, 2009 | 12:51 PM
Da Gumpmeister's Avatar
Da Gumpmeister
Not TMK. AND I M too dammt olt, to push one, to find out.
When we first got the pan, the dist. was so worn out, kikkin' was almost impossible. I would have Momma pull start me, using a tie down. Try that chit with ONE rear drum brake, and a WOMAN at the wheel!!!!!!! U B bizzeyer than a one armed wallpaper hanger, smokin' a joint. SOME things jus' shouldn't be tried. Can you say, time for a Mallory electronic dist.????
Old Jul 16, 2009 | 01:02 PM
kwb377's Avatar
kwb377
I've bump started a couple of my EFI bikes before...
Old Jul 16, 2009 | 01:23 PM
carlgrover's Avatar
carlgrover
Back in the day I could jump the ironhead easy. Fast forward 25 years and an electronic ignition and I can't.
Old Jul 16, 2009 | 01:25 PM
Cyphilis's Avatar
Cyphilis
I have bump started my '99 Ultra several times when I was having charging problems.... its fuel injected and started up everytime with no problems. My stator and flywheel were bad, and the bike would not charge going down the road (I only realized this when I was 120 miles from home, 40 miles from any town at a lake) My Battery was so dead it wouldn't even click the starter over. I bumped it the first time when I was on top of a hill. The next 2 times, were at a gas station, and liquor store on the way home.. and that was with a buddy pushing me.
I always did it in 2nd gear. So yes, a fuel injected bike,.. with no power at all can be bump started, at least in my own personal experience.
Old Jul 16, 2009 | 02:31 PM
harleyguy5571's Avatar
harleyguy5571
I've had to do it to my 90 FXR when me charging system took a chit.
