Wondering what your thoughts are on using Castrol GTX (20W-50) Drive Hard for the primary. Any of you use it? I have about 5 quarts left sitting on my shelf that I'd like to use up (used to use it in my BMW). I use Mobil-1 75/140 Synthetic for my tranny, Mobil-1 20W-50 V-twin Synthetic for my motor and currently running Formula + for my primary. Please let me know your thoughts.
I wouldnt use it for 2 reasons. Believe 20-50- is to heavy for primary ( i use 10-40 AMSOIL) and it PROBABLY HAS NO FRICTION MODIFIERS FOR CLUTCH SLIPPAGE. Its your call!
20w-50 isn't too heavy as it was recommended by HD at one time. You don't want the friction modifiers in an oil used in a wet clutch application. The 10w-40 and up viscosity oils will generally not cause clutch slippage as they don't have to be formulated to meet the very low friction specs the lower viscosity oils do for our modern car engines.
That's what I thought, but I wasn't sure. Always good to ask first. I think you might appreciate that article that was posted to this thread. check it out. Interesting read.
Amsoil is a great product, but difficult to find because of their distribution system, so for that reason I use Mobil-1 in engine and tranny. I've had good results.
+1, This is the same oils that I'am going to this change and from now on..
I have used the F+ since the 1k with 0 problems, now 21K. I wont change Clutch oils around.
Been using syn3 in motor, no more, no complaints, just think M1 VT is better.
Have Bel-ray 80-145 in tranny now, no issues, just want to go with full Syn in tranny, so it will be M1 75-145 lube from now on.
Motor oil isn't a magic elixir that is to be poured in all holes on a bike as some would have you believe. Just because you can doesn't necessarily mean that you should, it's not the "ideal" stuff to be using in your tranny and chaincase.
