Removing a glued grip.......
Old Aug 18, 2009 | 04:23 PM
Bluzmn59's Avatar
Bluzmn59
I have heard that compressed air works, even on old bikes. I have never tried it or seen it done, though.
Old Aug 19, 2009 | 08:56 AM
huffhuff's Avatar
huffhuff
i removed my Kury grip when i had the bar off by immersing the grip in a large plastic soda cup (not foam) of acetone. used a thin screw driver to pry the grip to allow the acetone to penetrate inside. after a few minutes the grip screwed right of easily. the acetone will desolve the glue. also of note, a couple of ounces of acetone in your gas will increase the octane.
Old Aug 19, 2009 | 09:18 AM
golfblues's Avatar
golfblues
Ok, the cage that encases the rubber is metal on the ISO's so I had to dremel it off by cutting the side bars. Then I cut the grip off with a knife & cleaned off the bars. I couldn't save the grip so I have one useless ISO throttle grip. Too bad, the grip is very high quality & a shame to waste. I'm surprised they don't make a non glue version like the OEM's.
Old Aug 19, 2009 | 09:34 PM
RageAndMachine's Avatar
RageAndMachine
lick it all over like a popsicle then stand on one leg and hop around in circles singing your favorite nursery rhyme. it should come right off then.
Burbur2
Sep 11, 2018 11:38 AM
bigboomerFLSTC
2014-2024 Touring Models
25
Sep 7, 2014 12:16 AM
lateralus
Jun 1, 2012 06:34 PM
Jack Straw
May 11, 2011 07:57 PM
EzRyder
Detailing
23
Dec 28, 2007 08:41 PM
