Need some helpon some speakers
at most you need is 100 watts per channel, and make it a good amp that delivers the 100. Not a pyramid, kraco, VR3 amp. Like rockford, alpine, MTX, kenwood,, something that delivers the promise of power. Low distortion figures are a must. like better than .05%
You need to find the maximum output of your charging system and add the load of the bike with the lighting on and all the accessories while running. Most touring harleys with radios have more than enough electricity availiable to run a couple hundred watts, not really needed, 100 should be fine.
assuming an amp is fused at 5 amps...if it is 100% efficient (i bet it aint) it wont put out more than 70 watts before the fuse blows.
My 50 watt amp is fused at 5 amps, so you know it has to draw less than 5 to sustain the fuse. Thats less than your 55 watt headlight.
Another thing amps only pull that heavy amperage for a split second when there is a bass note or low frequency sound. thats why subwoofers are fed with huge amps and tweeters need much less power.
100 watts would be just dandy. It will run 4 speakers just fine.
here is an Orion, a great amp, under $100 at Crutchfield.com
- 2-channel car amplifier
- 60 watts RMS x 2 at 4 ohms (80 watts RMS x 2 at 2 ohms)
- fused at 25 amps.
95db 1w/1m
50 x 2 amp under the seat next to battery.
Electronic crossover under right side cover.
Loud enough to hear with a full face helmet on at 85.
Good crisp sound, lacks a little bass due to small tiny speaker size.
Sound from my mp3 player!
How often will you run the radio wide open? You can still use your speakers. Those speakers will out perform most other speakers only using 100 watts, while the lesser speakers may be operating at 150+ to get the same volume.
Lower power means longer life too. Use em anyway.
